First post, by Blorthos
I am new to DOSBox.
I am installing a product that uses 4 disks labeled "GAMENAME 1" through "GAMENAME 4"
It checks the drive label between each phase of the install.
I have each disk extracted to a different folder
c:\games\gamedisk1\
c:\games\gamedisk2\
c:\games\gamedisk3\
c:\games\gamedisk4\
This lets me mount the install disk
mount b "c:\games\gamedisk1\" -t floppy -label "GAMENAME 1"
The install gets through the first disk, but then it prompts me for a disk labeled "GAMENAME 2", but I can't get back to DOSBox to swap the label because I'm mid-install.
What do I do?
Reply 1 of 4, by jmarsh
Don't extract the disks, keep them as images and mount them all using imgmount. You can then switch between them using ctrl-F4.
Reply 2 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
jmarsh wrote on 2020-07-05, 03:07:
This is the best way, but you will need an SVN built of Dosbox
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 4, by konc
Dominus wrote on 2020-07-05, 08:49:
Isn't this included in the latest 0.74-3?
Reply 4 of 4, by _Rob
As mentioned, get dosbox svn, dosbox ece or dosbox-x and don't mount them as folder mounts, but rather as disk images with a command similar to this.
imgmount a disk1.ima disk2.ima disk3.ima disk4.ima
You can start the install, and when it asks for disk 2, swap the disk with the disk-swap key combination.
