First post, by kixs
just wondering what will happen if someone put an Intel 486DX2/66 in Nexgen motherboard and power it on? I know a silly question, but I saw a photo of it and I'm wondering if the motherboard could get damaged by it? Would the pins acutally fit!?
Reply 1 of 11, by BinaryDemon
Different sockets / pin counts.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 3 of 11, by mpe
It wasn't very easy, but I am strong...
The density of pins in the NexGen socket is almost exactly double 😀
Reluctant to turn it on though. It would almost certainly blow up something...
Blog|NexGen 586|S4
Reply 4 of 11, by The Serpent Rider
Wrong side though =P
Reply 5 of 11, by mpe
Which side is the correct one?
Blog|NexGen 586|S4
Reply 6 of 11, by kixs
This is the photo:
Reply 7 of 11, by The Serpent Rider
*grabs popcorn*
Push the button, Max!
Reply 8 of 11, by mpe
Let me put an educated guess. Given most pins in either socket are power points it is almost guaranteed there is a short +4V (or whatever the voltage is) to ground somewhere. Depending how quickly you switch it off there will be a strong current that would destroy the CPU socket with the typical blue smoke effect. The CPU might actually survive just like the rest of the motherboard. But I might be wrong.
Blog|NexGen 586|S4
Reply 9 of 11, by The Serpent Rider
I will survive - 486.
Reply 11 of 11, by kixs
I think it wasn't really turned on. But you never know...
