First post, by squelch41
I am trying find a decent, compatible doom launcher for DOS. PC spec in signature at the bottom (486 133MHz)
I've been trying Zdoom but it only offer 320x200 which displays as strecthed widescreen on my tft which is annoying and there are some sound glitches.
What do others use? There seem to be loads out there but it is quite overwhelming working out when ports switched to windows, which actually work, etc etc!
Any help with sifting would be appreciated!!!
V4P895P3 VLB Motherboard AMD 486 133MHz
64mb RAM, CF 4Gb HDD,
Realtek 8019 ethernet + XT-IDE bios ROM, ES1869 soundcard, VLB Cirrus Logic GD5428 1mb VGA
440bx MSI 6119, modified slocket , Tualitin Celeron 1.2Ghz 256mb SD-RAM, CF 4GB HDD, FX5200 gfx
