Reply 20 of 28, by Muz
cyclone3d wrote on 2020-10-28, 22:42:
Muz wrote on 2020-10-28, 21:35:
I have another problem, DELL P2214H (the NVIDIA High Definition Audio), has no sound, but my Headphones (High Definition Audio Device) has a sound, but the sound stutter a bit when playing Warcraft 2 BNE. The screen and frame rate looks ok, but only the stutter sound problem now....
Is there a PCI latency setting in the BIOS? If not, then you should be able to get a Windows based PCI latency utility.
Either way, try lowering the PCI latency to 32. Normal setting is usually 64.
Where is the PCI latency in the BIOS?
Reply 22 of 28, by Muz
I am getting this weird error when I try to run PCI Latency.
Reply 23 of 28, by Jorpho
Could it be that you need to run the program from an account with administrator privileges..?
Reply 24 of 28, by BEEN_Nath_58
Could you please explain more specifically what is fast, I don't have any problem on the BNE.
Reply 25 of 28, by Akuma
Discrete_BOB_058 wrote on 2020-11-04, 16:19:
I think he's talking about the screen scrolling speed when you're near the edges.
That problems is also present in DOSBox, so I use fixed cycles=30000 there.
And that means: too much power 😒, so this guy is right.
dr_st wrote on 2020-10-27, 17:21:
Too much power!!!
Reply 26 of 28, by Jorpho
Akuma wrote on 2020-11-04, 16:38:
I think he's talking about the screen scrolling speed when you're near the edges. That problems is also present in DOSBox, so I […]
Except that he's confirmed now that he's running the BNE Windows edition and not DOSBox, and said "The screen looks stutter when I run the game", not that it's scrolling too fast.
But then again,
jmarsh wrote on 2020-10-28, 16:11:
It's Muz. Treat all details as tentative at best.
Reply 27 of 28, by Akuma
Jorpho wrote on 2020-11-04, 18:13:
Where did I state that he is using DOSBox ?
Reply 28 of 28, by BEEN_Nath_58
NVIDIA high Definition is not for Speakers or Headphones, and if your High Definition Headphones have stutter sound, try with a different driver. Or else try with a speaker if you have and identify if the problem is driver or hardware.
