First post, by JayAlien
Hi All,
I’ve been wanting to play The Secret of Monkey Island, but my floppy disks are corrupt as mentioned on another thread:
Help with disk images
I’ve been unable to source disk images, and I purchased the VGA version on CD as a result.
Note, original hardware throughout.
I cannot get any sound out of this game, I’ve tried the I, A, S, R attibutes for audio on two different PCs, both of which output sound on other games. The PC’s I’ve tried this on are:
DOS: Pentium 75 (caches disabled~386 speeds), SB16 (IRQ7), MT-32, 8MB
DOS: Pentium 100, S3 Virge DX, AWE64 (IRQ5), MT-32, 32MB
Two things of note, when I use the S attribute, I hear a click from the speakers, as if the sound card initializes, but no music. When I use the R attribute, the MT-32 displays ‘Lucasarts’ but then nothing. I know the CD version has CD audio, but my understanding was you could still override this and play sound from hardware, rather than off the disk. Any ideas what’s going on?
Thanks,
J
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700Pro A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX Xfi 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 1 of 6, by foil_fresh
The cd version you are using, is it "monkey island madness"? If so i will install and see if i can get fm or roland modes working with it on the awe64 (it emulates mt32 fairly ok in win98)
Reply 2 of 6, by cde
I had a similar issue which was solved by switching to DOS 6.22's MSCDEX plus VIDE-CDD (instead of the equivalent from FreeDOS).
Reply 3 of 6, by JayAlien
Not my disk, but my disk looks like this:
klmduws1mjl41.png?width=750&format=png&auto=webp&s=2a2b4ec1d461a1118e0fcf026cbafcc735caff5a
Thanks,
J
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
Reply 4 of 6, by K1n9_Duk3
All the music in the CD-ROM release should be CD audio tracks. Just make sure you have the CD audio cable connecting your CD-ROM drive to your soundcard and that the CD volume is not muted in your soundcard's mixer settings.
This topic has already been discussed in this old thread. Seems like the CD version can't play anything other than the CD audio tracks for music.
However, the sound effects should still be using your soundcard or PC speaker, so try opening and closing the door to the SCUMM Bar and check if that produces any sound. If you hear any sound from that, this would prove that the game has detected your sound hardware correctly and simply refuses to play and OPL/MIDI music because it comes with CD audio tracks.
Reply 5 of 6, by JayAlien
Thanks for the info, I just confirmed that putting this in a Win98 PC with CD audio cable connected, I am getting music.
What's odd is the parameters for sound cards are still listed, throwing me off.
Now if someone was feeling generous about disk images on my other thread, I'd be able to play the EGA version with MT-32 audio..... anyone???
Thanks,
James
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
Reply 6 of 6, by cde
TBH I have tried the MT-32 and in my subjective opinion sounds less good than the two alternatives (Adlib and CD audio) ; using a DreamBlaster X2 with BURAN 1.0. Not the DreamBlaster X2's fault however (it sounds great in many other games such as DOOM).
