First post, by shrad
Hello there, new on this forum, I have not seen any presentation section here so I'll directly ask 😀
I have acquired an old Epson NB3s in working state except the hard disk, and would like to have a go at replacing it but this system needs a system disk to be able to modify bios options.
My questions are simple : is there somewhere an utility that will modify generic bios parameters like a proprietary system disk would do, or is there someone with a floppy image of the Epson system disk?
Also, if I do not have the opportunity to change hard disk settings, would it be possible to install a disk manager in the MBR and just match the initial disk config for the first partition to be able to boot?
Thanks a lot for the answer!
Reply 2 of 8, by NScaleTransitModels
Have you considered drive overlay software? I've had excellent results with EZ-Drive 9.03W, as described here: EZ-Drive Dynamic Drive Overlay
It should allow you to boot from any hard drive (and access the full drive) without needing to match the original hard drive parameters. As long as the parameters are set to something in the BIOS, not "not installed" or "auto".
Builds:
  • ECS FX-3000; 386DX-40@50; ET4000AX, ISA 1mb
  • Acer VI9; 486DLC-40; Mach32, VLB 2mb
  • Chicony CH-471A; CX486s-40; Mach32, VLB 2mb
  • Gateway 2000 P5-60; Pentium-60@66; S3 928, PCI 3mb
  • DTK PKM-0033S; AM5x86-133@160
Reply 3 of 8, by darry
There is an Epson ftp archive on archive.org . It might contain what you need . It is over 200GB in size, however .
https://archive.org/download/2015.02.download … pson-europe.com
Reply 4 of 8, by shrad
Thanks a lot fot those two responses, they will help for sure!
HDD setup is done with either disk type or head/cyl/sect and I have the original parameters so it will be ok, the only thing will be to find a functional set of floppies to play with
I'll try this out before downloading a 200Gb archive 🤣
Will post a picture once revived, next step will be to teplace the CdNi cells in the battery with some more recent cells, and it will be a good retro machine
Reply 5 of 8, by PC Hoarder Patrol
shrad wrote on 2020-11-19, 09:50:
Thanks a lot fot those two responses, they will help for sure! […]
This may be what you're looking for
rd-nb3s.zip
250.38 KiB
61 downloads
from here (there's also an nb3s.zip which may be a BIOS file)
ftp://ftp.epson.it/pub/es/compu/
Reply 6 of 8, by shrad
Holy crap! this is a nice one, thanks!
I had a go at disassembling the beast, not a small task and I didn't even take pictures... some screws at horrible places and the chassis was even held by several port mating screws... a nightmare
Also, the floppy reader bracket holds a spring which retains one of the two screen locks, and I had to replace it by a cobbled spring which doesn't quite do the job 😒
Sometimes the urge takes me to disassemble things, I just rage after myself afterwards 🤣... at least it is almost intact and still works, so as soon as I have floppies at hand I'll try to write a floppy image with the archive you attached
Reply 7 of 8, by shrad
I had the opportunity to test the disk and other bootable floppies like dos 6.22 and the like, but it didn't boot and would only display a message when no HDD was present (no system disk error)
It seems the floppy drive is fried, or the bios is not correctly reading the disk because it boots correctly on a VM, either a floppy image or the raw disk
If somebody has ideas they'll be welcome, replacing the drive with a classical one seems to require an adapter cable for power and I didn't have time today to make an adapter
