Reply 20 of 35, by matze79
https://www.youtube.com/watch?v=wW1th462IKM
root42 does it again ? 😀 lets wait
root42 Hey everyone! Soooo sorry. I botched it. I will have to do the stream tomorrow.
root42​I put in the wrong date in my YouTube and my personal calendar. Sorry guys and gals!
Stream tomorrow!
Reply 21 of 35, by matze79
Revision Update:
i don`t think it makes sense to make Quad DAC just use two Dual Cards and mix Outputs.
There is really only one Program Supporting it 😀
Now Mono Playback on LPT Adresses, Stereo on different.
Still have to choose "hopefully" Conflict Free Adresses, any Suggestions here ?
Reply 22 of 35, by Grzyb
matze79 wrote on 2020-11-22, 17:11:
Consider 16-bit address decoding - this would allow addresses like 378h+400h, 378h+800h, 378h+C00h, and so on...
Reply 23 of 35, by root42
Or: Use 16 bit port writes. I.e. 378h+379h to be able to write both L and R samples with one 16 bit out instruction.
YouTube and Bonus
Reply 24 of 35, by Grzyb
BTW, I've found a special LPT card which can be set for both standard and non-standard addresses:
3BC
378
278
268
27C
26C
Reply 25 of 35, by digger
@matze79 A bit of topic perhaps, but can you perhaps share the workflow you use to get such high quality visual renders of KiCad designs?
Recently I rendered a 3D image of a KiCad design of another project (using the example instructions found at Hackaday), and importing into Blender and such proved quite a hassle. I eventually got it to import properly, but I didn't even come close to getting the quality that you got, because I skipped on a lot of the suggested tweaks described in the guide at Hackaday. Perhaps you found a more automated script somewhere that can do this for you? Or are you just very experienced and proficient with Blender (or other 3D rendering tools)?
Thanks. 🙂
Reply 27 of 35, by digger
matze79 wrote on 2020-11-23, 23:28:
You just have to change the 3D Preview to ray tracing.
It’s part of Kicad.
https://kicad.org/discover/3dviewer/
Ach so! 😅 I've played with the 3D preview before and I wasn't impressed with the quality, but I didn't know it also had an actual high-quality ray tracing option. I should have examined all the bells and whistles of KiCad better. Thanks!
Reply 28 of 35, by Jo22
Grzyb wrote on 2020-11-23, 23:15:
BTW, I've found a special LPT card which can be set for both standard and non-standard addresses: 3BC 378 278 268 27C 26C […]
3BC
378
278
268
27C
26C
3BC kinda was the original port address for LPT1..
It was hard-wired on Hercules compatible graphics cards (HGC, MGA)..
They also lacked an IRQ, not sure, speaking under correction here..
Anyway, never had an issue with it, except that some programs expect 378h as being the first parallel port.
Which it is, except if 3BC is in the system. Then 378h becomes LPT2..
Edit: http://wearcam.org/seatsale/programs/www.beyo … pp/parallel.htm
Reply 29 of 35, by Grzyb
Jo22 wrote on 2020-11-25, 08:52:
Yes.
3BC, 378, 278 are standard addresses, supported by BIOS.
268, 27C, 26C are non-standard, but if somebody made an I/O card with these, they are also worth considering for similar projects.
MDA uses IRQ7, but it's optional, and for many years no software used LPT IRQ.
That's why IRQ7 was the default in early Sound Blasters.
But then there came some OS/2 version with background printing - via IRQ, and that's why later Sound Blasters use IRQ5 by default.
Reply 30 of 35, by matze79
How does a PC LPT detect ? does BIOS check for Status Registers to be present ?
Reply 31 of 35, by root42
matze79 wrote on 2020-11-25, 14:14:
According to Sergey Kiselev's implementation the BIOS just writes a test value to the LPT and reads it back. If that is succesful, it assumes a printer port at that address.
https://github.com/skiselev/8088_bios/blob/bb … rinter1.inc#L97
YouTube and Bonus
Reply 32 of 35, by matze79
R1 arrived and works as expected 😀 looks bit ugly because of desoldered parts but! it works!
No longer flip switches for Mono / Stereo
My First PCB with KiCad
Reply 33 of 35, by jskyboo
matze79 wrote on 2020-12-03, 17:48:
covox.jpg […]
Are you still working on this design? Have you tried adding DSS support? Is the r1 available for sale either complete or as a kit?
Reply 34 of 35, by matze79
Yeah, i have a new design on draft for 1 year but didnt order it yet.
it supports auto detection as lpt port so debug is no longer needed and also auto stereo mono switching.
No there is no shop to buy it.
I also didnt upload the files to github yet. i was just too lazy, eager to do other stuff 😀
only 3 cards where ever made.
Reply 35 of 35, by jskyboo
matze79 wrote on 2022-09-25, 17:20:
Yeah, i have a new design on draft for 1 year but didnt order it yet. it supports auto detection as lpt port so debug is no lon […]
Very impressive, I hope you return to the project someday I would love to see that r2 in action!
