First post, by imp
As in the subject. I get the sound when I run the game with VDMSound, so I guess it's a matter of tweaking the config somehow. I haven't got any ideas though. Any advices?
PS. The game runs in slow motion when I run it without the emulator so I can't play with just VDMS.
Reply 1 of 7, by catchaserguns
I got the game and I run D-fend with Dosbox. Mine is configured with SB16 address 220 IRQ 7 DMA 1 HDMA 5. You might want to get D-Fend Frontend. Its easy to use.
Reply 2 of 7, by wd
Rank DOSBox Author
DOSBox Author
That's the default of dosbox btw., so it should run the same with
no frontend at all.
Is there a setup/installer of the game? If so, maybe you didn't configure
the sound settings correctly.
Reply 3 of 7, by eL_PuSHeR
Or maybe you need very low cycles for sound autodetection.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 7, by imp
It worked! Thanks! 😀
Reply 6 of 7, by PerryRhodan
I had similar problems with the original DOSBOX 0,74, so I changed to DOSBOX X which works perfectly with everything on auto. The only thing I don't like is screen tearing. Is there any way to fix this in DOSBOX X? I've set force Vsync in the advanced display settings but I'm still getting screen tearing.
