First post, by Battler
Does anyone have the datasheets for the Intel 420TX and 420ZX? All I can around is the first few pages from each, which is of not much use. So if anyone has the full datasheets of these, it would be greatly appreciated.
Reply 2 of 5, by Battler
That only documents the southbridges, and not the northbridges.
Reply 3 of 5, by Horun
Battler wrote on 2020-12-19, 11:59:
Same here, the Intel Peripheral Components 1994 pdf had the most but still very limited info.
Reply 4 of 5, by mpe
Let me know if you find one.
In the meanwhile, the datasheet for 420EX can be found and it has similar feature set as the 420TX.
Blog|NexGen 586|S4
Reply 5 of 5, by Horun
mpe wrote on 2020-12-19, 22:41:
Yes did find that 420EX one. The 420TX/ZX used 3 chips, not 2 chips like 420EX. Odd that the docs to the
82423 DATA PATH UNIT (DPU) and 82424TX CACHE/DRAM/CONTROLLER (CDC) are so hard to find.....
Will dig around some more later, found the Intel Classic/PCI i486 Baby-AT models BP4S33AT, BP4D33AT, BP4D266AT
used the 82424TX/82423TX chips so maybe some digging that direction will be helpful...
