First post, by Takedasun
Video card Nvidia Riva 128.
How do I turn off vertical synchronization (vsync) in Direct3D games?
i don't think it's an option in the drivers but maybe rivatuner or powerstrip can change something
Don't do that, disabling vsync on riva 128 or TNT is not allowed by default for a reason 😀
Riva Tuner not support.
PowerStrip
Frequency limited to 60 fps
Probably can be disabled directly via registry tweaking.
OpenGL already has Vsync disabled.
The Serpent Rider wrote on 2021-01-04, 05:29:OpenGL already has Vsync disabled.
And AFAIK cannot be enabled.
The Serpent Rider wrote on 2021-01-04, 05:29:Probably can be disabled directly via registry tweaking.
[HKEY_LOCAL_MACHINE\Software\NVIDIA Corporation\RIVA 128\Direct3D]
"NOVSYNC"=dword:00000001
is not working
Looks like you'll have to switch between drivers. Some should work.
