Problems with 2.4.0
First post, by dancing.sphinx
Greetings, all! I have downloaded and installed newest build of MUNT - 2.4.0. (amd64 version)
And now starting mt32emu-qt.exe gives me this error.
Any suggestions?
Previous build (2.3.0 amd64) worked like a charm on the same system.
Reply 1 of 9, by Cyberdyne
Pretty hard to understand, if you do not know russian 😁
Reply 2 of 9, by sergm
Hrmf, I'll double-check if the build contains all the runtime libraries bundled...
In the mean time, installing MSVC runtime for Visual C 2017 should help, hopefully.
Reply 3 of 9, by sergm
Ah, and it seems I should test it with Windows 7 😉
Reply 4 of 9, by dancing.sphinx
sergm wrote on 2021-01-20, 15:05:
It seems this is the reason) Yes, i use Win7 x64
Could you fix it, please?
Reply 5 of 9, by sergm
I'll see what I can do. You know, the world around is updating all the time 😒
Reply 6 of 9, by sergm
After nuking some weird garbage from the static build that cmake has pulled in, the build has become compatible with windows 7, it seems.
Reply 7 of 9, by dancing.sphinx
sergm wrote on 2021-01-20, 21:12:
Thank you! It works again. At least on Win7 x64 SP1.
Reply 8 of 9, by sergm
Thanks for reporting! I'm pretty sure that I'd never find it 😉
Reply 9 of 9, by Spikey
FYI, it worked on my Win 7 always. 64 bit also.
