Reversing the Disney Sound Source
Reply 140 of 146, by digger
Question for shock__ and matze79:
Which post (either here, or on dosforum.de, or any other forum or site) contains the most up-to-date revision of your design?
Also, perhaps it would be better to publish it on GitHub, to keep track of revisions and allow collaboration on improving it further?
Thanks for this really cool project, by the way. 😃
Reply 141 of 146, by Kulich
I'm joining with the same entreaty. What is the last version of this project, zip archive with PCB design and parts list files? This post vogons.org/viewtopic.php?p=405296#p405296 ? Is it fully working bug free version?
Because I saw another newer version, USB powered, DSS/Covox switched, here https://dosreloaded.de/forum/index.php?thread … 5059#post105059 What are differences?
Compaq LTE Elite 4/75CX, LTE 5280 + Multibay Expansion Base
ThinkPads 570E, 701CS, 760XL, 770, X41T, few T4X, T6X and main T400
Toshiba T3200SXC
Reply 142 of 146, by digger
Dreamblaster, if you happen to read this, please consider making a CVX5 which can be switched between Disney Sound Source mode, Covox Speech Thing mode and Stereo-On-1 mode. 🙂 Such a device would be really useful, since the DSS is supported in quite a few more games than the Covox Speech Thing! Such a device would sell quite well on Serdashop, and shouldn't be hard to make for a skilled retro hardware designer. The DSS is only slightly more complex, with its FIFO buffer.
Reply 143 of 146, by matze79
You can load TEMU also and use some DSS Games and play Tandy 3 Voice Games too, for example Monkey Island works fine 😀
Reply 144 of 146, by matze79
digger wrote on 2020-11-11, 00:53:
Question for shock__ and matze79: […]
Most current Version are CD40105 Version as far as i know, there only minor differences, added Diode, USB Header..
i think latest is on Dosreloaded.de,
Reply 145 of 146, by Kulich
matze79 wrote on 2021-02-12, 12:17:
So... it's not this post - Re: Reversing the Disney Sound Source with archive? Have to look at dosreloaded.de.
Sry for silly question, that USB header is for powering amplifier?
Toshiba T3200SXC
Reply 146 of 146, by LordMortiferus
The latest tested and released version is indeed on dosreloaded based on shock__'s original design as well as matze79's revision. I was working on a version with integrated R2R-ladder DAC as well, albeit it is neither tested nor has it seen a public release (If anyone is interested sent me a PM). The most sophisticated version to this point is an unreleased prototype by shock__ with the afore mentioned covox/dss switch.
Attached you will find the latest release from the dosreloaded forum.
Btw, is there a way to change the Vogon's username? Or could some admin please change my name to Kanpai ?
