Unknown Soundcard
First post, by Demerzel
Hello Vogons
this soundcard (i think it is one) is laying around here quite a while and i am wondering what brand/type it is.
Googling was not successfull so far. Maybe some one on the Forum has a clue what it could be ?
Greetings
Demerzel
Reply 1 of 3, by etomcat
Demerzel wrote on 2021-03-13, 16:29:
Hello Vogons
Hello, Is there an "FCC ID" mark on the card? I have a very similar one and it has FCC ID J5QMF-001 on th backside which can be looked up on the web as a Preton Technology brand Adlib clone soundcard. BR: Tamas Feher.
Reply 2 of 3, by Benedikt
No idea about the brand, but the type of sound card is stupidly obvious:
It's an AdLib compatible! The big 24-pin package and the small 8-pin package give it away.
They can sand off as many numbers as they want.
Maybe it has a resistor DAC for PCM sound, as well. The number of resistors on the card is suspiciously high.
Reply 3 of 3, by Demerzel
No FCC ID on the Card.
But if it's a AdLib Compatible card then drivers shouldn't be a problem.
Thanks a lot !!
Greetings
Demerzel
