Socket 478 and the very rare LGA 775 board for PIAGP industrial setup if you want full ISA support.
You can have up to about 7 ISA slots and 4 PCI slots... or more PCI slots and less ISA slots. You also get 8x AGP.
See here for the backplanes and options:
http://www.ewayco.com/26-Backplanes-PCI-ISA-P … nes-pciagp.html
https://www.amcuk.com/agpbus.php
Basically, you need a backplane with the PISA kit (the PCI to ISA bridge board) and an SBC.
If you don't care about full ISA support (DMA for sound cards), then you can go way higher.
The backplanes usually go for around $100 + shipping on eBay and the SBCs are all over the place.. but usually just as much or more than the backplane.
If you don't care about AGP... which is kinda silly, you may be able to go a bit higher and still get full ISA support, but you need to make sure the SBC includes a PCI-ISA bridge chip that supports DMA for ISA.
IEI-PXAGP-13S3(R)-datasheet1-1153846873.pdf
