The Fluid soundfont name in that listing is the name of the folder. The soundfont is the same as online. The Synergi soundfont's unpacking is incompatible with Webroot Secure Anywhere. It hangs on tidy.exe. The registration code is in a text file in the Synergi directory. You have to burn this to disc with Nero with an iso file that is mailed.
I took my computer to the Geek Squad and had it deep cleaned. I had webroot SA off when I ran the executable and this is what I got,
Later, tiny.exe was removed by an antivirus Sweep.
