First post, by WazMeister
Hi All,
I have several games, CD ROM version but on HDD (free ware downloaded).
Example being BASS (searched on here but not much relative), DiscWorld etc...
If I try run them, it either says can not find disk or during install says please insert disc in A:/
BASS installs, about 1kb worth and using sky.exe just makes screen flicker with DOS.
Is there something I must do for these to work?
Gabriel Knight CD works, just running sierra.exe, I have original CD but 486 has no CD rom drive. But no voices....
Reply 1 of 10, by chinny22
Don't know those exact games but in my experience
The good thing for dos games is most don't have any copy protection. 9 times out of 10 if you copy the CD contents to your HDD and run the installer from there it maps back to the source files.
Sometimes it needs the same file structure as the CD (so files/folders need to be coped to c:\) sometimes it's smart enough that you can put it in a sub folder and make it more tidy.
I've also a game (megarace I think) that wants mscdex loaded, the fact that my 486 also doesn't have a CD drive doesn't matter, it just checks its loaded then goes off and uses the files on the HDD
But then have another game that will read off the HDD just fine as long as mscdex ISNT loaded.
a few dos games have NoCD cracks if you look. Need for Speed SE is the only game I have that I still haven't found a work around for.
Reply 2 of 10, by WazMeister
oh, thank you so much for reply. Really helpful!
What is MSCdex, sorry?
Reply 3 of 10, by thepirategamerboy12
chinny22 wrote on 2021-03-23, 10:15:
Don't know those exact games but in my experience The good thing for dos games is most don't have any copy protection. 9 times […]
With MegaRace, you can just copy the RACEPRG.EXE and MEGARACE.DAT files to the game's directory on your hard drive and modify the batch file that was created by the installer. Other Cryo games like Dune and Lost Eden work pretty similarly. Many DOS PC games that don't use CD audio can be made to run entirely from the hard drive with some tinkering of batch or configuration files. There's also a tool called FAKECD you can try for games that specifically look for MSCDEX, so far I tried it with the awful Zorro game by Capstone and it worked fine. I'm tempted to make a video tutorial on this topic someday...
Reply 4 of 10, by Jorpho
An alternative to fakecd is SHSUCDHD, which emulates a CD-ROM drive using an image file (i.e. BIN/CUE). Of course, this requires you to have lots of hard drive space. And it still won't let you play redbook audio.
WazMeister wrote on 2021-03-23, 09:09:
I have sevenral games, CD ROM version but on HDD (free ware downloaded).
DiscWorld is not freeware.
There is also not much reason to play these on a 486 when you can use ScummVM to play them on almost any device and have a nearly-indistinguishable experience.
Reply 5 of 10, by chinny22
WazMeister wrote on 2021-03-23, 10:51:
It a part of dos that lives in your autoexec.bat file used to load the CD-ROM driver, usually its something like
LH C:\DOS\MSCDEX.EXE /D:mscd001 /l:D
Config.sys would also have something like the below (oakcdrom.sys been a fairly generic driver)
DEVICEHIGH=C:\DOS\oakcdrom.sys /D:mscd001
thepirategamerboy12 wrote on 2021-03-23, 15:46:
Maybe I got it the wrong way round and MegaRace didn't like mscdex loaded and that other game needed it. I cant for the life remember what the other game was, lucky I one had 1 game that needs it and 1 that cant have it, rest of my games don't care, of it they did I already had the No-CD for it.
Reply 6 of 10, by Warlord
It's dos cd rom driver and cds don't work without it.
Reply 7 of 10, by mothergoose729
Does streaming data still work? Like redbook audio and FMV?
Reply 8 of 10, by chinny22
mothergoose729 wrote on 2021-03-24, 19:50:
[Does streaming data still work? Like redbook audio and FMV?
FMV still works as it's just data files end of the day but redbook audio wont work.
Some games like Warcraft or Age of Empires have midi music to fall back on if the CD was missing, others like C&C dont actaully use redbook. but yeh quite a few games you'll loose the soundtrack
Reply 9 of 10, by mothergoose729
chinny22 wrote on 2021-03-24, 20:34:
You know, redbook audio is really rare. I'll have to give that a try. Since I have ripped all of my CD games anyway it is pretty easy to look at the cue sheet and see if there are any tracks or not. Thanks for the tip.
