Roland SC-55 Settings
First post, by alamar
Hello,
I picked up an early version of an SC-55 (ROM 1.10 - GS Logo on front - no general midi), and reset it to factory defaults after I was having some issues. Was curious if there is recommended settings / guidance for each instrument and part for the Level, Pan, Reverb, and Chorus settings as a number of games now sound a bit funky and off.
Thanks in advance!
Reply 1 of 5, by Joseph_Joestar
Default settings is what you want for games. Performing a GS reset will ensure that the device is using those.
Afterwards, you can compare your SC-55 with online recordings such as this one.
Reply 2 of 5, by alamar
Joseph_Joestar wrote on 2021-04-03, 17:58:
Thanks! I totally forgot about the GS init - appreciate it!
Reply 4 of 5, by Joseph_Joestar
keropi wrote on 2021-04-03, 22:13:
Just remove the battery: each power on will be defaults 😉
My SC-155 remembers settings even without the battery, unless I disable the "Backup switch" option.
To clarify, this happens when I press the Power button to turn off the SC-155. If I physically remove the power cable from the device, it does reset to defaults, regardless of the Backup switch.
Reply 5 of 5, by Spikey
alamar wrote on 2021-04-03, 17:46:
Hello,
Thanks in advance!
It's basically your preference. With Sierra games for example, I like them having some reverb and chorus, so I play a QuestStudios MIDI file that heightens the level of both prior to gameplay. I keep the module off until the logo comes up, so it doesn't reset it. 😀
