Forgotten Realms
First post, by dnewhous
If you run install.exe from DOSBox you get the following error message after selecting continue.
2021-04-21 21_16_59-DOSBox 0.74-3, Cpu speed_ 3000 cycles, Frameskip 0, Program_ INSTALL.jpg
Is there anything that can be done about that?
Daniel L Newhouse
Reply 1 of 5, by eL_PuSHeR
[Thread moved to DOSBox subsection]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 5, by Jorpho
dnewhous wrote on 2021-04-22, 02:23:
People keep replying to your posts, and you never give any indication that you are learning anything from what people are trying to tell you.
Reply 3 of 5, by dnewhous
Jorpho wrote on 2021-04-22, 18:09:
I have learned from this forum. Now I've run into bugs that I hope can be resolved in a future version. The version of Dungeon Hack that comes with Forgotten Realms Collection 3 would require D-70.sf2.
Daniel L Newhouse
Reply 4 of 5, by Jorpho
dnewhous wrote on 2021-04-26, 20:10:
If you've learned anything it should be:
  1. Your problems are far more likely to be due to errors on your part than due to bugs in DOSBox.
  2. No one is going to be able to fix any "bugs" unless you DESCRIBE IN DETAIL EXACTLY WHAT YOU ARE DOING so that someone else can reproduce the "bugs".
Reply 5 of 5, by dnewhous
Believe it or not, DOSBox has come a long way. Now that they've added fluidsynth to DOSBox -X there's something else that can go wrong. The sound effects in Lord of the Rings were flubbed somehow, they've been fixed.
I got Eye of the Beholder to work with the Silver Collection. It's start.bat to start.
Daniel L Newhouse
