First post, by scrufy12parsecs
Greetings,
I'm running DOSBox 0.74-3, which I installed from package on the latest version of Mint GNU/Linux. I'm trying to install MS-DOS in DOSBox, which I'm close to completing. Where I'm getting stuck is being able to swap disks in the installation. Ctrl-F4 opens another TTY, since I'm on GNU/Linux instead of swapping disks. Is there another key combination that I can use or define? Does my autoexec.bat look correct? When I start DOSBox from the shell, I can see that it's loaded each installation disk and don't see anything that stands out as an error. Thanks for taking the time to offer some advise.
My autoexec.bat
imgmount a "/home/scm/OS/MS-DOS/Disk1.img" -t floppy
imgmount c "/home/scm/OS/DOSBox/MS-DOS.img"
boot "/home/scm/OS/MS-DOS/Disk1.img" "/home/scm/OS/MS-DOS/Disk2.img" "/home/scm/OS/MS-DOS/Disk3.img"
Reply 1 of 5, by Jorpho
The standard version of DOSBox does not support floppy swapping. You need an SVN version for that.
Reply 2 of 5, by scrufy12parsecs
Jorpho wrote on 2021-06-01, 01:48:
Thank you Jorpho for your reply! That saves me a lot of time. I'll look into that.
Reply 3 of 5, by BitWrangler
Also all the DOSbox binaries in distribution repositories are quite old and buggy as hell, you're better off compiling from source for standard DOSbox
Reply 4 of 5, by jmarsh
To workaround the hotkeys switching the active terminal, you can run DOSBox with the "-startmapper" argument to open the keymapper and rebind the "Swap Image" operation to a different key combination.
Reply 5 of 5, by kjliew
scrufy12parsecs wrote on 2021-06-01, 01:08:
... I'm trying to install MS-DOS in DOSBox ...
But why? No DOS games would demand a true MS-DOS to play. You could just mount a folder and start playing DOS games right away. That's the beauty and simplicity of DOSBox for DOS games and you don't seem to appreciate that ... 🤣.
