Like Abit VP6 but with 2 ISA slots
Reply 20 of 24, by paradigital
You can mod the sockets on a BP6 to take coppermines, we did that to a friends board back in the day. No idea if it would subsequently take Tualatins in adapters though!
Reply 22 of 24, by cyclone3d
moog wrote on 2021-06-01, 15:20:
evasive wrote on 2021-05-28, 08:36:
Using an ISA riser card on the VP6 maybe?
Will that enable me to address the ISA card from HMI drivers or DOS games in broad terms?
You can theoretically add as many ISA slots as you want. It just comes down to power requirements and signal clarity.
The ISA bus is all shared so there isn't anything special you have to do to have more slots. You can access them the same exact way as the slot on the motherboard.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 24 of 24, by cyclone3d
No. The white port is PCI. The black port is ISA. If you look closely, you will see that the ISA port is just a passthrough and not connected to the PCI port at all.
YMF7x4 Guide
