Reply 20 of 30, by brostenen
kixs wrote:
Have you managed to get 3.45V cpus to work?
Nope...
Not with cache enabled/detected. My 5x86 is running on the board.
I actually do not know why, but that's ok, as I feel that a 5x86-133 is a bit too fast.
I will keep it as it is for now. Intel dx2-66, 16mb Parity ram.
For slower need's I have a 386sx33 with 387 co-processor and 4mb ram.
For even slower need's I have a 286 8/10-mhz with 640kb of ram.
And for faster, I have parts for a Pentium-133 or 166.
Reply 21 of 30, by kixs
So you're running 5x86-133 at 5V?
If it's of any help, this is my old Rev C2 board configured for 256KB cache and 3.45V AMD 486DX4-100WB.
Reply 22 of 30, by brostenen
Yeah...
That CPU and two different i486dx2-66, one a486dx2-80 and an i486dx-33.
I might be doing something wrong, though I will test the other CPU's later.
Rught now, it is running good enough, with an i486dx2-66.
Reply 23 of 30, by kanecvr
brostenen wrote:
Thanks for the heads up.... :-) I simply can not see the markings for PIN-1. Nor 2 and 3 for that matter. (think I need glasses) […]
Thanks for the heads up.... 😀
The manual does not state anything about what are the right pin's.
Is 1 towards the memory modules, or is 1 towards the tag?
Don't remember, but it's written on the board. Pull the jumpers off and carefully look under them and around the pins. I think pin 1 is near the tag cache socket.
Reply 24 of 30, by brostenen
Oh boy..... Do I feel stupid. I was looking at the pins with the jumpers on them. 😁
Anyway...
It is running, and I am satisfied with this. It feels like a snappy system. 😜
Reply 25 of 30, by RiP
Just found one LS486E rev. C but sadly I can't get it to work, no beep 🙁
Reply 26 of 30, by wbhart
I can confirm that on my board the 33MHz setting is 5-6 (not 1-2 as in the manual). In my case jumper W2 was also missing (not mentioned in the manual) and it didn't boot without it.
Absolutely no beeps or display without setting those correctly, though setting the cache jumpers incorrectly didn't stop it POSTing for me.
3.3v chips work just fine for me. In my experience when they don't work it is because writeback is set incorrectly. Trace pin B13 of the ZIF socket to the jumpers with a multimeter. It may break out in more than one place, so look out for that.
(Also, on some boards pin C10 must be tied low with a jumper for the CPU to start up, though that is not relevant for this board, as it is correct in the manual.)
YouTube Channel - PCRetroTech
Reply 27 of 30, by maxtherabbit
On mine, either 1-2 or 5-6 will produce 33MHz
Reply 28 of 30, by RiP
brostenen wrote on 2016-10-25, 00:21:
Posted with an dx33 and dx2-66. Guess this board can not run 3v CPU's.
All my 5volt's have posted now. Board set up with Intel 486dx2-66 and 64mb 60ns FPM.
Could you get it to work with 3V CPU?
My LS-486e rev C2 works only with 5V CPU 🙁
Reply 29 of 30, by Baoran
Mine says that it is rev D. Are the big differences between the revisions? I have not noticed compatibility issues so far.
It is small size so it is usually the first motherboard I use when I need to check if a isa or pci card or a hard drive... etc works.
Reply 30 of 30, by brostenen
RiP wrote on 2022-09-22, 21:26:
I dont remember. I posted it around 6 years ago.
