First post, by TelamonLivesOn
I've been trying to find to CPU pinout for Slot 2 CPUs for some time, but have only been able to find the pinout for Slot 1 CPUs. Does anyone happen to have a reference diagram of this, or know of where to find one? Thanks!
Reply 1 of 6, by H3nrik V!
I assume it's the pin designations and all, you need? I have found this, regarding connector design, if it does anything for you;
https://www.google.com/url?sa=t&source=web&rc … Y1i8q6EW7QIdBGB
Reply 2 of 6, by TelamonLivesOn
H3nrik V! wrote on 2021-06-16, 19:07:
Thanks for this. And yes, I am looking for the Pin Designations, as I will be designing a PCB in the future that will make use of these CPUs. I will certainly keep this document in mind when designing.
Reply 4 of 6, by H3nrik V!
TelamonLivesOn wrote on 2021-06-16, 19:26:
That sounds extremely interesting 😀
Reply 6 of 6, by PC Hoarder Patrol
TelamonLivesOn wrote on 2021-06-16, 19:52:
Thank you very much!
No problem...here's a couple more Intel docs (also with the pin definitions) for better context
Pentium® III Xeon™ Processor at 500 and 550 MHz
24509401.pdf
Intel® Pentium® II Xeon™ Processor Bus Terminator Design Guidelines
24377401.pdf
