ATI Windows 9x DDC/EDID override
First post, by swaaye
While playing with the Radeon 8500 on VGA output, I ran into the usual problem of fighting the monitor EDID. My LCD's EDID lacks useful things like 1600x1200 support and for some reason identifies its max resolution as 1920x1080 even though it's a 2560x1440 screen. I really like 1920x1440.
In XP the EDID can be overriden by a checkbox in the ATI drivers, but not in Win98.
I did some web searching and came across an old forum post on Rage3D saying there's an undocumented registry setting for the ATI driver to ignore DDC/EDID in Win9x.
HKLM/Software/ATI Technologies/Driver/0001/DAL
"DALRULE_CRTSUPPORTSALLMODES"
binary set to "01 00 00 00".
It works great. I was using Catalyst 6.2 at the time. Could be risky with a CRT though. Might want to assign refresh rates with HZtool first.
https://www.rage3d.com/board/showpost.php?p=1 … 989&postcount=1
Reply 1 of 26, by Tiido
I hoped this would be able to defeat the "panning" I get from higher resolutions than 1600x1200 but unfortunately it didn't, I did get ability to use much higher refresh rates though ~
Reply 2 of 26, by swaaye
Tiido wrote on 2020-07-28, 02:12:
I was getting the panning too. Even with the monitor INF installed that specifies 2560x1440 and the supported frequencies, the ATI driver prioritizes the 1080p EDID.
I wonder why it isn't entirely working for you. Is the "detect Plug and Play monitors" checkbox on the monitors panel in display properties checked or unchecked?
Reply 4 of 26, by darry
I don't even get a picture on my 1920x1200 monitor (Acer VW257) at start in Windows 98SE if I don't run my FX 5900 through an EDID emulator with a simplified EDID . This is not due simply to the monitor supporting 1920x1200, as a Dell U2412M did not have that issue . The hardware EDID emulator route is more expensive, but more foolproof in the long run,
IMHO . It's definitely time somebody came out it with a home-brew, inexpensive and easily programmable EDID emulator design geared towards retro users . The closest commercial product that fits the bill is about 100 USD on a certain auction site (Aten VC060 and VC080) .
Alternatively, you can build your own, like cde did . See [HOWTO] Running DOS games natively with perfect 4:3 aspect ratio @ 70 Hz over DVI
Reply 5 of 26, by swaaye
darry is that DVI? I think I remember your thread. Yeah DVI on old cards is troublesome. Some cards can't drive even 1280x1024. I do have a DVI EDID emulator because I use this 1440p monitor and that is often dead in the water with old cards.
My situation here is VGA though. I don't really need an emulator for that. NVidia and ATI usually let you override EDID and it will never come up blank. XP is easiest to deal with. Win9x was tricky until this registry tweak for ATI.
VGA is usually preferable to me unless I am using a dual link DVI card that can actually run 2560x1440. VGA supports higher resolutions than single link DVI (1920x1440 is nice!)
Reply 6 of 26, by swaaye
Jorpho wrote on 2020-07-28, 02:46:
Last time I had to mess with something like that, I created an INF for my monitor and modified it accordingly, as in http://web.archive.org/web/20100906042110/htt … graphics-cards/ .
The problem here is ATI won't drive anything above the monitor's EDID unless you can disable that behavior. In XP they have a checkbox in the control panel. Nothing in Win9x though, which is where this registry tweak comes in.
I did spend a couple hours messing with INFs but I noticed it was always peaking at 1920x1080, which is what the EDID reports. It would do the panning 1600x1200 desktop at 1920x1080 for example.
Reply 7 of 26, by darry
swaaye wrote on 2020-07-28, 04:21:
Sorry I did not notice your initial post was about VGA, not DVI . That said, VGA EDID emulators do exist as well, but a registry entry is both simpler and cheaper .
I personally have not yet moved above 1600x1200 on retro hardware and I don't know if I will any time soon . My hope is that OSSC Pro, when it comes out, will give us the best of all worlds and eliminate any reliance on VGA monitor inputs, monitor aspect ratio controls, any EDID issues and scaling compromises .
EDIT: 1920x1440 at 60Hz may be possible under single link DVI with custom timings using a reduced blanking interval .
Reply 8 of 26, by Tiido
swaaye wrote on 2020-07-28, 02:33:
The box used to be unchecked, but I found it had got checked again. Unchecking it (and restarting) didn't seem to make a difference. I do have a monitor INF made that specifies all imaginable resolutions and refresh rates being usable. Only way I have got past the panning has been through making custom resolutions using PowerStrip, it seems to do what is necessary to defeat the panning. I haven't looked much into what it changes in the registry, especially since I have no vanilla setup at hand to play with.
Reply 9 of 26, by swaaye
Tiido wrote on 2020-07-30, 01:41:
It is mysterious. I actually found that I don't even need a INF once that registry tweak is applied. The PNP detected monitor works with all resolutions. I deleted the INF out of Windows/INF/Other and removed monitor entries from device manager.
Reply 10 of 26, by swaaye
darry wrote on 2020-07-28, 04:52:
I got it working indeed. I had to use Powerstrip to add it, at which point I got an image but it wasn't working right. The NVidia control panel let me get CVT-RB configured though and now it's perfect. Very nice!
Reply 11 of 26, by jakethompson1
This may be a bit of an abrasive solution, but in the days of onboard ProSavageDDR VGA, and Linux X.org, I had issues with how it was detecting modes from a widescreen LCD monitor, and my ultimate solution was to "pluck" the DDC pin out of the VGA cable so that it had no choice but to obey my modelines.
Reply 12 of 26, by swaaye
jakethompson1 wrote on 2020-08-02, 03:49:
I was planning to do that but then had the thought to do some searching on whether anyone had figured out how to unlock all modes on Win98 with ATI cards. And I found that registry tweak.
On XP it's easy to override the EDID. And with NVidia cards it's easy in both 98 and XP. ATI makes it hard in Win9x.
That's with VGA of course. DVI is more tricky.
Reply 13 of 26, by darry
swaaye wrote on 2020-08-02, 03:38:
Nice! It's remarkable how flexible those nearly 20-year old TMDS chips and their Nvidia implementations can be .
Reply 14 of 26, by bloodem
swaaye wrote on 2020-08-02, 04:00:
I actually have a similar issue with nVIDIA cards and my monitor whenever I install Detonator 4x.xx or newer drivers in Windows 98.
My monitor in particular (an AOC 1440p 75 Hz display) exposes two EDID modes (not sure why). The second mode lists 1920 x 1080 as the maximum resolution, and for some reason the new nVIDIA drivers seem to pick up on this second mode and stick with it, while drivers such as 3x.xx or older see the correct 2560 x 1440 max resolution that is exposed in the 1st EDID mode.
So far I haven't found a solution to force the new nVIDIA drivers to ignore EDID (and I have tried everything, including multiple versions of Powerstrip, creating custom drivers, forcing different monitor drivers, etc).
Could you tell me what easy way you have found that has so far eluded me? 😁
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 15 of 26, by swaaye
bloodem wrote on 2021-06-24, 14:56:
I actually have a similar issue with nVIDIA cards and my monitor whenever I install Detonator 4x.xx or newer drivers in Windows […]
Are you using DVI or VGA? I would suggest to just use VGA and bypass all the DVI dual link nightmares with single link cards. You can also get access to 1920x1440 with VGA whereas DVI single link can not handle it.
Your monitor's dual EDIDs seems likely to be a way to workaround compatibility problems with old single link cards. Specifying a limit of 1920x1080 is much more likely to get you an image from old cards. It's still too much for some oldies though.
I haven't played with any old stuff in months though so can't be of much help because I don't remember the specifics offhand.
Reply 16 of 26, by bloodem
swaaye wrote on 2021-06-25, 18:47:
Yes, I'm always using VGA - not only because I can achieve higher resolutions, but for various other reasons as well: like the fact that my monitor (and all other monitors that I came across) can only modify the aspect ratio when using the VGA connection (on DVI I need to rely on GPU drivers... which is a no-no on Windows 98). Also, the video quality, particularly in MS-DOS, is MUCH better on nVIDIA cards when using VGA.
I see... 🙁 Man, this is killing me, I have been trying everything with newer nVIDIA drivers and nothing works with my monitor. So the only option would be a magic registry setting like the one you found for ATI drivers, but if there is such a setting... it's very hidden, because nobody seems to know of its existence. 😁
Reply 17 of 26, by swaaye
bloodem wrote on 2021-06-25, 19:34:
After thinking some more about this I think I remembered what you need to do to get access to all resolutions. Uncheck the box circled in this image and reboot.
Reply 18 of 26, by bloodem
swaaye wrote on 2021-06-28, 04:20:
Thanks, swaaye... Unfortunately that was one of the first things I tried: disabling the "Automatically detect Plug & Play monitors" option, and even forcing various monitor types that support high resolutions such as 1600 x 1200.
For some reason, it doesn't work in my case. With nVIDIA drivers 4x.xx or newer, the second EDID mode is still automatically used, which limits the resolution to 1920 x 1080...
Reply 19 of 26, by swaaye
bloodem wrote on 2021-06-28, 05:37:
Oh the funs. 😀
Maybe I will do some experimentation. Which NV card are you using?
