First post, by unbirthday
UPDATE: Added working link 20/06/2023.
I present my patch for Shadow Warrior. It turns off that pesky auto-tilt whenever you go up or down a slope. The patch also writes a new SW.CFG and patches SW.GRP with modern WASD/mouse bindings, so that you can see the bindings in the F1-key screen whilst in-game.
If someone can please suggest a better place to upload little files for free, I'll take them all. Something that doesn't spy and preferably outside silicon valley would be pleasant (If someone uploads to a better place, I'll paste it here too).
https://www.mediafire.com/file/e0pv0sn6yoovk5 … wtiltp.zip/file
Here's the readme for the lazy
SWTILTP: Shadow Warrior Tilt Patch, by Unbirthday. Jan 22nd 2021.
This program will patch SW.EXE to remove the auto-tilting issue, where your camera view will tilt automatically when going up or down a slope.
swtiltp Linux 64 bit binary
swtiltp.exe MS-DOS 32 bit binary
swtiltp_x64.exe Windows 64 bit binary
Just put the swtiltp binary (bin/) into the same directory as Shadow Warrior v1.2 and run it. It will patch SW.EXE; Write a new SW.CFG with mouselook and keys configured; It will also patch SW.GRP, adding in updated F1 screens.
Reply 1 of 2, by Msciej
Does anyone have this patch? The link is dead.
Reply 2 of 2, by filurkatten
If you want to apply this auto-tilt=off patch to Wanton Destruction and Twin Dragon what you need to do is hex edit;
Address: 000F9E80
From: C7 89 B9 16 01 00 00 F6 81 8D 4B 00 00 80 74 21
To: C7 90 90 90 90 90 90 F6 81 8D 4B 00 00 80 74 21
in the WD.EXE and dragon/SW.EXE files.
