Reply 20 of 39, by Kahenraz
- l33t
I think I found the problem. I think any further triage should be put on hold until this one is solved. I spotted a missing surface mount capacitor. But I don't know its value to safely replace it.
My capacitance meter reads about 300uF on nearby ceramic capacitors. Could that be accurate?
If you look closely, it's actually visible in the first photo with the whole board.
