First post, by Speedwarrior956
It Goes like this:
As I was trying to play this one -which appears to be based on FIA's European Truck Racing Championship. Go Figure!- and go thorough the in-game controller settings, It doesn't work with my XONE (as in XBOX One) gamepad as it can't detect it, pretty much to my dismay. I was wondering if there's a good workaround to enable them and give this cool racer a good spin thorough its paces. #PleaseHelp
Reply 1 of 6, by Procyon
You'll be needing an Xinput to DirectInput emulator/converter.
Try to Google them as there are several but I myself never had the need for them.
Reply 2 of 6, by Speedwarrior956
Procyon wrote on 2021-08-15, 19:59:
I've tried every single Dinput-to-Xinput emulator that ive got in my "arsenal" including XOutput, which appears to be the newest one to date.
It appears to be some sort of hardcoded fuss going on in there, if the game's registry entries are something to go by. Let's try it on Windows 95 compatibility to be sure......
UPDATE: Nope. Didn't work either
Reply 3 of 6, by Procyon
Maybe get an older gamepad which supports DirectInput.
I've got a couple of old Logitech gamepads (Dual Analog, Rumblepad 2) and they work fine with older games and I can even use them with Xinput games when I use x360ce.
If you get one of the F series they support both DirectInput and Xinput by simply flipping a switch.
Reply 4 of 6, by Davros
If your in the U.K theres this for £1.79 (the postage is more)
https://www.scan.co.uk/products/mercury-kob43 … -digital-joypad
Or if you want something a bit more versatile
SpeedLink Strike NX USB Gamepad for PC
it switches between direct input and xinput it will also act like it has an xbox pad layout if you want it to
its £10.99
https://www.overclockers.co.uk/speedlink-stri … -gc-00c-sl.html
Reply 5 of 6, by Speedwarrior956
Davros wrote on 2021-08-28, 13:24:
If your in the U.K theres this for £1.79 (the postage is more) https://www.scan.co.uk/products/mercury-kob43 … -digital-joypad […]
its £10.99
First time hearing and/or reading about them. How good they are? #TellMeRealGood
Reply 6 of 6, by Davros
Sorry for the delay, I have no idea about the first pad, the second is pretty good even has rumble I'm happy with mine
