First post, by m0rd
ok so im having trouble with ems on this system. When i use the onboard video i get a emm386 cant use frame memory error on boot, but Qemm seems ok with onboard video. When i add a vga card qemm tells me that emm has put the frame buffer in conventional memory. I have tried setting 386emm in the configs.sys but it still not working??? the system has 4mb ram. i tried without any card installed but still same. Do ibm ps2 have wierd ram setup??? never had this with me other 386 and 486 systems.
Reply 1 of 4, by Predator99
What CPU do you have? These memory Managers require a 386 At least.
Or do you have a EMS card?
Reply 2 of 4, by m0rd
386sx 25 upgrade board
Reply 3 of 4, by mkarcher
It seems you are using a Model 30/286 PS/2 computer. This computer, with no extension cards installed should have the whole range from C000-DFFF free, because the VGA BIOS in part of the 128K mainboard ROM between E000 and FFFF. With a VGA card installed, the on-card BIOS takes C000-C7FFF, but you should still have 96K continous unused upper memory which is enough for a page frame.
Can you post a photo of the memory map, as shown by either checkit, or MSD or Quarterdeck's Manifest (MFT)? MFT shows the memory map in the "1st MB" category.
Reply 4 of 4, by m0rd
k ty ill try get pics next few days as im booked up abit
