First post, by matti157
I have a 12MB 3dfx Voodoo2 - the Creative CT6670 version. I am testing the card for the first time.
I installed it in the pci slot, copied the .OVL driver from its original Creative CD into a folder which I then added to the path environment variable
I downloaded the GTA 3dfx DEMO from here https://www.dosgamesarchive.com/download/grand-theft-auto/ and then I deleted the OVL included in the game folder to make sure that the one from the Creative CD is used
But when I start it, the 3dfx logo is already reproduced at 1-2fps, if I wait for the end and let the game start, the fps are those. It is completely unusable.
The computer is an IBM 300GL 6282
Pentium MMX 233mhz
64mb SDRAM
DOS 6.22
On the compatibility matrix, the game is out of box compatible Voodoo 2 DOS Glide compatibility matrix
Reply 1 of 16, by SScorpio
Did you try it with the original OVL file? If a game is out of the box compatible with a Voodoo 2, you shouldn't need to change anything.
Reply 2 of 16, by Gmlb256
You must use a GLIDE2X.OVL file from an older Voodoo2 driver since the ones that comes on the recent drivers has compatibility issues. Also it seems that a patch is required but you are using the demo version of the games.
The GLIDE2X.OVL file included on games are usually meant for Voodoo Graphics.
Reply 3 of 16, by matti157
SScorpio wrote on 2021-09-06, 12:38:
With the original OVL the card is not recognized, the game stopped at a "Select your Voodoo" screen without giving me the option to select the card.
Reply 4 of 16, by matti157
Gmlb256 wrote on 2021-09-06, 13:03:
What do you mean for "The GLIDE2X.OVL file included on games are usually meant for Voodoo Graphics."?
Reply 5 of 16, by Gmlb256
matti157 wrote on 2021-09-06, 15:12:
The original OVL file that comes with the game may not work on the Voodoo2 because that card was released when DOS was going out of mainstream support.
Voodoo Graphics = Voodoo 1 like most users here say.
Reply 6 of 16, by matti157
I try with various versione (Creative 2.16, reference 1.2.51, 3.2.2 but nothing:(
Reply 7 of 16, by Gmlb256
matti157 wrote on 2021-09-06, 22:48:
Well, I'm going to download the demo and test it on my old computer and let you know.
Reply 8 of 16, by Gmlb256
Downloaded the demo and deleted the GLIDE2X.OVL from the game directory and it worked flawlessly.
Note that I disabled the 3Dfx splash screen through an environment variable (FX_GLIDE_NO_SPLASH) and the GLIDE2X.OVL file that I'm using for DOS dates from Apr 3rd 1998 and comes from an early reference driver (1.2.50).
Reply 9 of 16, by matti157
Gmlb256 wrote on 2021-09-06, 23:03:
Thanks, I'll try tonight
Reply 10 of 16, by matti157
I tried with the version 1.2.50 but is still unplayable...
http://falconfly.3dfx.pl/voodoo2.htm
The FPS has increased slightly but it will be 5fps ...
Am I CPU limited?
Reply 11 of 16, by Hezus
matti157 wrote on 2021-09-08, 09:03:
I tried with the version 1.2.50 but is still unplayable... http://falconfly.3dfx.pl/voodoo2.htm […]
Am I CPU limited?
No, that 233 mmx can run the game easily.
Visit my YT Channel!
Reply 12 of 16, by Errius
I have a similar rig but I've never tried running the game under pure DOS. I run the DOS version under Window 95C. No problems.
Is this too much voodoo?
Reply 13 of 16, by Pierre32
I recall it running pretty decently for me under DOS with a P200 non-MMX and Voodoo 1.
Reply 14 of 16, by Joseph_Joestar
Am I CPU limited?
Unlikely. I just tried the 3DFX GTA demo that you linked on my Pentium MMX 166 + Voodoo1 system and it ran fine.
I used the OVL file that was included with the game.
Reply 15 of 16, by Gmlb256
Am I CPU limited?
No. Seems that the problem is something else with your computer. Does other DOS Glide games works fine on that computer?
Using the OVL included with GTA with Voodoo2 will get you a "What 3dfx card?" on the screen.
BTW, 64MB DDR RAM? Should be SDRAM in this case.
Reply 16 of 16, by matti157
Gmlb256 wrote on 2021-09-08, 11:31:
No. Seems that the problem is something else with your computer. Does other DOS Glide games works fine on that computer? […]
Am I CPU limited?
I have the same message with the included OVL
Yes SDRAM 😅
