Reply 100 of 131, by LSS10999
shadowmage wrote on 2026-06-22, 18:30:
Thanks for the link. I tested the vga-ddraw wrapper on Windows NT 3.51, and both the StarCraft demo and the Red Alert 1 demo wor […]
Thanks for the link. I tested the vga-ddraw wrapper on Windows NT 3.51, and both the StarCraft demo and the Red Alert 1 demo work.
WineD3D does not work with the StarCraft demo for me either, but vga-ddraw does. Interestingly, the opposite is true for the Commandos demo: it works with WineD3D, but not with vga-ddraw.
The following games also work with the vga-ddraw wrapper on NT 3.51:
Baldur’s Gate demo, Age of Empires demo, and Age of Empires II demo, Heroes of Might and Magic III demo.
I have not tested the dsound wrapper from that project yet. I currently use dsound.dll from DirectX 7 or DirectX 8, and both work. I also forgot to mention that the Darkened Skye demo works on Windows NT 3.51 through 3dfx Glide, and dsound.dll from DirectX 8 works with it as well.
So far, compatibility seems to depend heavily on the individual game and the wrapper being used:
vga-ddraw: StarCraft demo, Red Alert demo, Baldur’s Gate demo, Age of Empires demo, Age of Empires II demo, Heroes of Might and Magic III demo.
WineD3D: Commandos demo, Heroes 3 demo and the previously mentioned Direct3D games.
Some games may work with one wrapper but not the other.
IIRC games utilizing Direct3D or OpenGL need something from ddraw.dll, but not the entire thing. Also, wrappers may not always implement everything and in modern Windows, they're deferred to the official DirectX dll in the system.
Back then I managed to get XTOM 3D to run using OpenGL (Mesa 7.5 GDI) and PAL-DDRAW, provided it's set to use the current system resolution. It's too slow to be playable at high resolutions (e.g. 1920x1080x32), but without any noticeable graphical glitch. Perhaps rebooting Windows with a lower resolution like 640x480 or 800x600 I might get a better, playable frame rate.
Note that PAL-DDRAW doesn't work with StarCraft or other DDraw games, as it doesn't cover some functions like DirectDrawCreate, which are deferred to the official DirectX ones.
So for now, vga-ddraw works for things that require full DDraw functionality, despite current limitations. For D3D/OpenGL games other wrappers may also work.
Reply 101 of 131, by Novanianer
Update the wrapper. You may need to launch the game twice for the wrapper to recognise whether it is using D2D or D3D.
please use a geforce 6/7 card with the forceware drive 77.72
starcraft, aoe, patricier 2/3,anno 1602 (1702 possible - not tested), baldurs gate 1 /2 , diablo 2, x tension, midtown madness (ony start but wip) , x2, ST Armada 1, "Have a nice day".
generell : wip
Reply 102 of 131, by Novanianer
Hi all, here is a new version.
d2d should be work. there some issue with keyboard inputs in textfields.
new: because the dinput x beyond the frontiert and xtension - 2 games with d3d support from 99/2000 was not developed for nt4, run on nt4 now.
Midtown madness dont run.
the old game "Knights and Merchants" run too.
please test and give me feedbacks.
Reply 103 of 131, by Novanianer
update
please help me for tests
xbtf and xtensions work please choose the dx7 dsound.dll and own (eigene) dinput.dll
x2 works too, complete with ingame animation (new ddrawex) , please use here dx8 dlls
anno 1701 is wip - (run without maxsound.dll)
midtown madness works too, but you must disable the npc.
test on geforce 7800, should work in geforce 6000 too
a own dsound and dinput is in process
Reply 104 of 131, by Novanianer
Novanianer wrote on 2026-07-20, 13:30:
update please help me for tests […]
update
Star trek Starfleet Command 1 and Star trek starfleet d3d worts too
Reply 105 of 131, by shadowmage
update
Hi Novanianer,
Thank you for uploading new version of WineD3D for NT 4.0! Which WineD3D version are you using? Is it based on an older legacy version? Could you also upload the source code for your WineD3D build that works on NT 4.0?
Reply 106 of 131, by Novanianer
shadowmage wrote on 2026-07-20, 14:19:
update
Hi Novanianer,
the "wrapper" base on wined3d 1.2 with many modifikation. as info source use is wined3d 1.7 and 9 , and "bill's version" from "experience" leak. but things have come to a standstill at the moment on d3d dx7 on armada....
important: the true wined3d / softgpu f.e. works with mesagl - over cpu , slow but one file for all. i use nvidia's icd, but nvidia remove some functions for gefore6/7.
sourcecode: later
Reply 107 of 131, by Novanianer
here the sourcecode
v91ARM - is not ARM - only a name for armada
I hope the others make progress.
Reply 108 of 131, by Novanianer
For DirectX on NT4, whether native (which is extremely difficult) or as a wrapper, you cannot swap files; you have to write them yourself. Newer versions are written in the wrong C++ or use APIs that NT4 doesn’t recognise, so they have to be adapted to the ICD. Not all ICDs support all OpenGL functions. NVIDIA’s ntoglnt.dll is actually quite ‘accommodating’ with OpenGL 2.0. 3dfx cards are good, but expensive. I don’t think S3 or SIS had any OpenGL support at all, or perhaps they used a wrapper themselves. Essentially, the only affordable options were ATI and NVIDIA.
Or you could write a new driver using OGL for NT4.
But then we’re back to ‘writing’ rather than copying.
I just copied d3d8/9 too 😜
Reply 109 of 131, by shadowmage
Novanianer wrote on 2026-07-21, 10:11:
here the sourcecode
Thank you for the source code, Novanianer!
Thanks to your WineD3D build, I managed to run various versions of Half-Life on ancient Windows NT 3.51, including legacy Counter-Strike versions.
For playing Half-Life, I use the OpenGL renderer, but on Windows NT 3.51 I still needed WineD3D for the game menus. Without WineD3D, I could not even get Half-Life to start. WineD3D is not really needed for the in-game 3D rendering, but it is needed to get through the menus.The latest Half-Life version I managed to run on Windows NT 3.51 is 1.1.0.8, along with Counter-Strike 1.3.
Here is my YouTube video. First, I play Counter-Strike Beta 6.1 on Windows NT 3.51, and then I play Counter-Strike 1.3 against bots. Counter-Strike 1.3 starts at 15:36. At the end, I also run and play Half-Life 1.1.0.8, which starts at 28:48. All of this is running on Windows NT 3.51 through QEMU:
https://youtu.be/BVAPO151v8U
And here is another YouTube video where I play Counter-Strike Beta 6.1 online multiplayer with real people (not bots):
https://youtu.be/1PZMPPC45Ms
Of course, all of this is also possible on Windows NT 4.0. On NT 4.0, I can also run and play Counter-Strike 1.5 and Half-Life 1.1.1.0, which for some reason do not work for me on Windows NT 3.51.
Reply 110 of 131, by Novanianer
shadowmage wrote on 2026-07-21, 12:06:
Thank you for the source code, Novanianer! […]
here the sourcecode
Well, in that case, the ChatGPT wrapper acts as a go-between. It tells the application what it wants to hear 😁
Reply 111 of 131, by Novanianer
d2d was rewrite on some points, there a separate surface for the mouse.
dx5 d3d work but with mini slight stutter - i downt know why - but NFS 3 run on nt4 - please use fakewindows:2000 + noglprobe
generell: WIP
tests with geforce 6/7
if you can GDI Mouse - use this - with software mouse there some texture glitches
if you can opengl - use opengl as renderer 😉
Reply 112 of 131, by digger
By the way, Windows NT 4.0 turned 30 today! 🥳
Reply 113 of 131, by Novanianer
I’m going to put the further development of dx4nt on hold for the time being. If anyone’s interested, they can publish the current source code here on GitHub and similar platforms. Perhaps someone else will take it forward.
My idea and recommendation would be to create a separate DLL for each D3D version (3, 5, 6, 7) to make troubleshooting easier. Ultimately, though, that’s something for whoever takes over the work to decide for themselves.
Reply 114 of 131, by Novanianer
The 3D games I remember from back then run on NT4, which is actually really cool.
It also shows, in my view, that a lot of what came after was just the same thing, only prettier and much bigger – and not necessarily better, but rather more complicated. For example, when I launch Word or Excel on my NT4 hardware (which is about 20 years old – but with an SSD), the whole process takes 1.5–2 seconds.
On modern devices running Windows 11 and Office, it takes longer for the application to start up. It’ll probably be the same on Windows 2000/XP.
Even when I look at the processes running on NT4/XP and now Windows 11, it’s a nightmare.
Personally, I think today’s applications are simply too big in terms of the amount of storage space and RAM they require. After all, it’s just a GUI that simply displays values.
And now the cat’s out of the bag!
I created everything with AI.
Whether that’s AI slop or not is for everyone to decide for themselves.
But as I’ve already mentioned in earlier posts, I had to do a lot of testing.
Reply 115 of 131, by LSS10999
here the sourcecode
AFAIK the ddrawex.dll in all versions I've checked have additional imports that NT 3.51 doesn't have (requiring NT4). Is this DLL mandatory for the wrapper's functionality?
If ddrawex is not mandatory, what additional DLLs are required for the wrapper to actually work? Regarding WineD3D, which version would actually work on NT 3.51?
EDIT: I just noted you're running this with QEMU. Don't know if everything can work with real HWs under certain circumstances...
I'm thinking of bringing up a NT 3.51 VM through QEMU/KVM (libvirt) if I have time, to experiment with this. Just not sure what configuration I should use.
Reply 116 of 131, by Novanianer
the ddrawex.dll do you need only for direct draw 8/9 contents. all older need only ddraw. the wrapper works without ddrawex.dll too.
Reply 117 of 131, by shadowmage
LSS10999 wrote on 2026-08-11, 08:11:
AFAIK the ddrawex.dll in all versions I've checked have additional imports that NT 3.51 doesn't have (requiring NT4). Is this DL […]
here the sourcecode
ddrawex.dll is not required. You only need "ddraw.dll" and "wined3d.dll" in the same directory as the Direct3D game's or application's executable.
I uploaded the PC Player benchmark as an example. In the directory containing the executable, it has ddraw.dll, wined3d.dll, and also "opengl32.dll" from the Mesa9x project.
This setup should also be usable on real hardware with Windows NT 3.51, Windows NT 4.0, Windows 2000, and Windows XP. It works for me under QEMU, and it should work under VMware as well.
Mesa9x is a better option than the older software Mesa implementation that works on NT 3.51 and NT 4.0. However, Mesa9x still uses the CPU for rendering in this configuration, so performance can be very slow.
The PC Player benchmark I uploaded is useful for testing because it is easy to exit, even when everything is running very slowly due to CPU-based rendering through Mesa9x.
Reply 118 of 131, by LSS10999
shadowmage wrote on 2026-08-11, 09:06:
ddrawex.dll is not required. You only need "ddraw.dll" and "wined3d.dll" in the same directory as the Direct3D game's or applica […]
I tested your PC Player benchmark with the wrappers you provided on a real NT 3.51 system. So far:
1. DDraw/D3D test works in "FullScreen" mode, though very slow. All modes (16-bit and 32-bit) seem to work, but the system resolution does not actually change since NT 3.51 lacks the capability.
2. Windowed mode tests do not work, with a D3D Message error saying:
CreateSurface for window front buffer failed.
The pixel format was invalid as specified.
3. DirectSound test won't work. When checked, erroring with "Bad wave file or file too big to fit in memory" followed with "Cannot create new buffer", and the benchmark eventually crashes.
I'm using VBEMP driver for video output, and the built-in Sound Blaster 16 drivers (SNDBLST) for my CMI8330. Everything except General MIDI works AFAIK (FM works).
CMI8330 doesn't have native NT 3.51 drivers that I know of, and its NT4 drivers do not work (no configuration passes when installing).
Reply 119 of 131, by shadowmage
LSS10999 wrote on 2026-08-11, 15:33:
I tested your PC Player benchmark with the wrappers you provided on a real NT 3.51 system. So far: 1. DDraw/D3D test works in "F […]
Glad to hear that the PC Player benchmark works! That confirms Direct3D acceleration is actually working on real Windows NT 3.51 hardware. Since it's a Direct3D 5 test, I mainly use it as a quick sanity check to see if WineD3D is working at all.
PC Player's windowed mode does not work for me on Windows NT 3.51 either. I have not really tested the sound part of PC Player, since I usually test audio in actual games instead (Rage Expendable for example).
Mesa9x is also slow for me on NT 3.51 because rendering is done on the CPU. The SSE3 variant of Mesa9x is considerably faster, but that version does not work on Windows NT 3.51. It works on systems such as Windows 98, 2000, and XP.
Here are some Direct3D games/demos that should work on Windows NT 3.51 and NT 4.0 with WineD3D:
Monster Truck Madness 1 Trial/Demo
Expendable
Alien vs. Predator (Alien Demo)
Tropico 1 Demo
Midtown Madness 1 and the Blood II demo may also work.
Monster Truck Madness 1 Trial is probably the best one to try first. It is one of the earliest Direct3D games, uses Direct3D 2, and also supports software rendering. Since it is not very demanding, there is a chance that it may run at a reasonable frame rate even with Mesa9x software rendering.
