Any sense buying modern PSU for old hardware?
Reply 100 of 263, by shevalier
Caesum wrote on 2026-05-05, 16:22:
Pardon me for asking one more time, but I was checking PSUs because the last one I wanted to buy was from some not-so-reliable v […]
Pardon me for asking one more time, but I was checking PSUs because the last one I wanted to buy was from some not-so-reliable vendor. Instead I found someone else and he has a Fortron PSU FSP 300W FSP ATX-300PNF from 2003. It says it is "W/PFC" but I assume it means Passive PFC not Active. There is one question about voltages though, it says it has:
+3.3.V == 20.0A, +5V == 20.0A, +12V1 = 16.0A, +12V2 == 16.0A, +5Vsb == 2.5A, -12V == 0,8A
(+3.3.V & +5V = 120W Max) (+12V1& +12V2 = 264W Max)
And now my question is, since it is (I assume) a Passive PFC PSU from 2003 with higher voltages on 3.3v line and 5v line then why max W is higher on 12V lines and does it mean this PSU is suitable for older eras computers or actually not?
A passive PFC was a temporary workaround that allowed any existing power supply to improve its power factor without any modifications in PSU themself. Its presence or absence has no effect whatsoever (from a home user’s perspective)
The high power output at +12V is because, at that time, it was a power supply unit of the latest ATX 2.3 standard, which marked the start of the focus on this bus.
The PNF series consists of robust PSUs based on tried-and-tested principles, so you’re unlikely to encounter any issues, though the voltage might read +12.3V instead of +12.0V.
This doesn’t affect anything, apart from the lack of round figures on the monitoring (provided the motherboard’s monitoring isn’t giving the wrong reading).
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 101 of 263, by AlexZ
Instead of PSU like that you can just go and buy a modern one with strong +3.3.V & +5V power load. They also have 120W+ max load. I would just avoid Standard/Bronze PSUs.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 102 of 263, by Mike_
Mike_ wrote on 2026-04-27, 16:31:
I opened up my Enermax 300W PSU out of curiosity. Capacitors seem to be fine, but I don't recognize their brand. […]
The attachment enermax_1.jpg is no longer available
The attachment enermax_2.jpg is no longer available
The attachment enermax_3.jpg is no longer available
The attachment enermax_4.jpg is no longer available
Speaking of PFC, is my Enermax active or passive PFC? It doesn't have a huge inductor like Fortron does, and it's only for 230V, with no selector switch.
Reply 103 of 263, by Caesum
AlexZ wrote on 2026-05-05, 16:43:
I thought so too at first but I was told that those might not provide a stable 3v/5v current especially the active PFC ones.
Reply 104 of 263, by momaka
Yes, that line of Fortron / FSP (ATX-xxxPNF) is with passive PFC, not active.
Whether the PSU is suitable for older PCs or not is always a tricky one to define.
Generally speaking, if the power rating (Watts) on the 12V rail grossly exceeds that of the 3.3V and 5V rails *and* the PSU is not known to have DC-DC converters (like some / most? modern PSUs do), then it's probably *NOT* suitable for a 5V-heavy PC.
With that said, I can actually answer this question about the above FSP model directly from experience: it is not suitable for a 5V-heavy PC. In fact, it does rather poorly with a 5V-heavy PC. If you feel like taking a very long read, you can do so at the thread below, there user Analog Programmer has a higher-power -rated FSP PSU of the same model line and wanted to see if it would be possible to convert the PSU to make it more 5V-centric. As I suspected (and towards the end of that thread), it is revealed that this is not possible to do on this PSU - not without some serious modifications (most of which would result in diminishing the PSU's efficiency in an effort to balance the voltages between the 5V and 12V rails.) Here's the thread:
[SOLVED] PSU Fortron/FSP ATX-350PNF with problematic +5 & +12V voltages
AlexZ wrote on 2026-05-02, 07:41:
A more modern Athlon XP board with P4/V12 connector would be the best choice, 2nd option is socket 754 (but you would also need CPU, probably a Turion 64) as it also has P4 connector. You would use a modern PSU.
I would not bet on period correct PSU lasting long, it will have to be checked periodically and probably recapped as they are too old. If you prefer trouble free solution then avoid this route.
I would sell the board + CPU to someone who doesn't mind fixing period correct PSUs and for the same price buy board + CPU with P4 connector.
Problem with buying an AXP board with a P4/12V connector is that there aren't that many choices and they are all likely to be more expensive, since they will be at the tail end of AXP era, where 333 and 400 MHz bus was more prevalent.
Socket 754 could be cheaper and probably eliminate many of the problems... but then maybe that does not bring the same nostalgia level to the O/P as the old s462 one? I know for myself that I certainly don't give s754 stuff the same nostalgic value as s462 stuff - especially if the old s462 was some Duron CPU where you could do the L-bridge mods to unlock extra cash or do other cool stuff.
As for period correct PSU not lasting long - again, I think that really depends on what one gets... and also a bit of luck, of course.
A few months back, for example, I got a 250 Watt OEM PSU likely either from a Dell or HP PC (not sure which) made by LiteON. It's a model that I already have a few of. I opened it just to see if there was anything obviously wrong, but there wasn't. Not even that much dust inside, which means it probably sat on a shelf for a very long time. Needless to say, I powered it up and after verifying the output voltages were OK (at least with a multimeter... my scope is out of commission at the moment), I put it on a spare junky PC and let it rip away. It's been fine so far.
shevalier wrote on 2026-05-02, 08:33:
@Caesum from Poland. The main problem in Eastern Europe is that local flea markets are being cleaned out by professional dealers […]
The main problem in Eastern Europe is that local flea markets are being cleaned out by professional dealers, and all the vintage stuff ends up being resold on eBay.
https://www.ebay.com/shop/asus-tusl2?_nkw=asus+tusl2
Finding something decent for a reasonable price isn’t exactly quick and takes a lot of luck.
Yeah, I see this is also starting to happen in Bulgaria now too. Though on my local flee market, some stuff somehow still falls between all of the dealers' and scrapers' fingers and then finds its way to me. For example, last week I was able to rescue a GeForce 4200 for a little under 5 Euro. As soon as did that, one of the known scrappers there went to the same guy I got the 4200 from and bought the rest of his GPUs and PC add-on cards. None of them were worth anything anyone would miss though, so I don't feel bad. The 4200 was a good save, though, and just at the right time.
Caesum wrote on 2026-05-01, 22:11:
Thank you guys for all the answers! While I didn't know buying a new PSU would be such a hassle, I learned quite a lot thanks to you.
At first I wanted to buy sth quicky so I could take it to my hometown for holidays, but it turned out to be so much more nuanced I missed my deadline so I'm taking a step back and will now look for offers more slowly lmao. I will update this thread if I find something worth mentioning.
Is the old refurbished Seasonic PSU you talked about a few pages ago not available anymore?
To me, that one seemed like a fairly good chance at being an OK option. (Unless it was just too expensive?)
Caesum wrote on 2026-05-05, 20:02:
Well, with FSP / Fortron, there's no definitely separation like that.
They did have some really old models with APFC that were actually pretty good for a 5V-heavy PC.
They also have much newer models without PFC or with just passive PFC that were horrible for 5V-heavy PC.
And then there's the reverse of both of these too: old models without APFC that were good for 5V-heavy PCs and new models with APFC that are akin to any modern group-regulated PSU with APFC.
So in other words, you still have to look at the label and use some "intuition" to more or less guess how the PSU would behave.
But again, the ATX-xxxPNF series from FSP / Fortron are not a good fit for 5V-heavy PCs, as I mentioned above.
By the way, I just got one of those ATX-xxxPNF series PSUs (an ATX-350PNF, I think??) last weekend with a PC from the local flea market. It is currently in pieces and drying outside on my balcony (needed a wash, since it was extremely dusty/dirty). Worth noting is that every single capacitor on the output is bulged and needs to be replaced. I didn't even think to plug it in as-is. Will be recapping it when it's dry.
So yes, with old PSUs, it is very possible to get one that won't be any good / will be in need of a full repair / recap.
Thus, I am certainly not claiming that all of the warnings that other members mentioned here about used PSUs are wrong in any way. In fact, they are pretty sound.
In my case, I just buy old PSUs, PCs, and other parts in larger quantities and cheaper... so if I get one PSU that is no good, I move onto the next.
With that said, if you can find a cheap source of used PSUs, just buy a bunch and see what sticks. Again, if you try to stick to the better OEMs, you have a higher chance of getting something decent that also probably works too. In particular, look for old Dell, HP, and Gateway PSUs that may have the following text in the model numbers:
any model beginning with "DPS" or "NPS" - these will be either Delta or Newton PSUs.
any model number beginning with "HP" - these will be HiPro/Chicony.
any model number beginning with "PS-" - these will be LiteON
Anything that says "Astec"
Mike_ wrote on 2026-05-05, 18:26:
Active PFC for sure.
Single 400V cap with a large toroidal inductor close by is the tell tale sign, usually.
Reply 105 of 263, by Caesum
momaka wrote on 2026-05-05, 21:18:
It's still available but the vendor seems massively untrustworthy as he has a lot of opinions about lying about their hardware + it costs about 23 EUR / 28USD which I feel is way too much to pay for a sketchy vendor. I will be looking for other PSUs.
Worst case scenario I'll just give up, strip the PC of the more interesting parts and throw the rest to the trash.
Reply 106 of 263, by AlexZ
I don't think anyone will be selling trully refurbished PSUs for 23 EUR. Probably just visually inspected + cleaned with a shower.
Some of the good brands suggested like Seasonic, Chieftec, Delta, HP may also have been used in servers, some sellers openly admit it locally. It may have been in continous operation for a very long time, like 10 years. Similarly to that is PSUs used in schools, libraries etc. Beware if anyone is selling more than 1-2.
Reply 107 of 263, by Caesum
AlexZ wrote on 2026-05-06, 13:29:
I agree with you because I gather it takes time and resources to fully refurbish a PSU. Unfortunately I don't see any vendors in Poland who actually do that. Mostly they just say it's "refurbished" with no details and when asked directly they either not respond or say they just cleaned it. They also have really bad opinions and some vendors even sell chinease non brands with Chieftec stickers or so. So I feel like paying 23EUR is a bit much for something that could just as well be a big lie.
It's still an option of course and I might buy it if nothing else shows up, but until then I'd just like to search a bit more (and ask for y'alls opinions if you don't mind).
Regarding that, I was also asking about PSUs on a Polish board and they recommended another option: buying a 2008-2012 era PSU with at least 130W on the 3x5v line combined. They also gave me a link to a particular PSU as an example. The question is, wouldn't that PSU be still too modern? It's a Chieftec 350W GPS-350EB-101 A and it looks really promising. It's not refurbished, but it's clean and tested using voltage tester, so the offer looks much more solid than anything I've seen yet + it's dead cheap too.
Reply 108 of 263, by shevalier
Caesum wrote on 2026-05-07, 17:41:
Its a cool power supply for an ATX whith a flyback design.
https://sector.biz.ua/docs/power_supply_schem … -350EB-101A.pdf
It’s a very rare topology.
As a collector’s item for enthusiasts – absolutely, but as a main power supply – I wouldn’t touch it.
It delivers 300 watts out of 350 via the +12V rail.
In other words, it has no advantages over a modern PSU (which comes with a warranty and a money-back guarantee).
Reply 109 of 263, by momaka
That's a PSU made by Delta Electronics - one of the best PSU manufacturers out there.
You can tell by the UL certificate number on the label (the backwards "UR" logo), which is E131881.
It is also a newer 12V-centric design... but I'd trust it would stay in spec/regulation a lot better than most other group-regulated PSUs.
So it may actually end up working OK with your PC, despite being a newer 12V-design.
And if it's dirt cheap, it's definitely worth a try, IMO. (BTW, how cheap are we talking about? If under 10 Euro, might even be worthwhile to grab two of them as a "warranty". 😉 )
Capacitor-wise, it's probably going to be all (or mostly) 2nd tier Taiwanese brands inside, but nothing downright terrible. Just the usual Ltec, and/or maybe CapXon.
I'm not sure what Delta does with their designs, buy these caps usually tend to last in Delta PSUs a lot longer than with anyone else - at least, that's been my observation over the years on many units.
shevalier wrote on 2026-05-07, 18:19:
It's not flyback, it's single transistor forward (typicaly called STF for short). Technically, they look the same on the primary side. But the transformers and output side is different. Flyback designs are discontinuous in nature, whereas conventional forward-converter designs are continuous. The difference is, the former does not have an output (coupled) inductor/toroid, as the transformer is gapped and thus acts like an open-core inductor. In contrast, the transformer used for continuous designs is not gapped and the output inductor after the transformer serves that function.
As for the Delta above, the only "unique" thing about it is that it actually uses two parallel MOSFETs for its STF topology.
In any case, STF is not a rare topology at all. Delta used it on quite a few of their PSUs starting from the very late '90s / early 2000's up until maybe 2009 or 2010, when they started also producing more two transistor forward PSUs. Two transistor forward is essentially almost the same thing as STF, but here the 2nd transistor (MOSFET) is added to cut-off power "above" the transformer, and then two diodes are used to re-capture the transformers back-EMF and dump it back into the primary bulk cap. This allows the primary-side snubber to be much much smaller, therefore greatly improving the efficiency.
Collectors item? Why? 🤣
You do realize there are still PSU designs still made with this topology. It's still a very widely used topology. Just not so much with ATX PSUs, mostly because STF typically tops out at about 350-400 Watts. Beyond that, the snubber on the primary really needs to grow in size to keep up with the higher power, and at that point it just doesn't make sense to use this topology.
Maybe so. But what about price?
A modern new PSU sure isn't going to cost peanuts. Whereas some of these older used PSUs can be found very cheap and still provide years and years of useful life without breaking the bank - in many cases, longer than the intended purpose of the PC hardware they are intended for. Again, this is a Delta PSU we are talking about here. While not impervious from getting bad capacitors, it is a lot more rare for them.
I run such PSUs almost exclusively around here... and it's not like a have much of a choice either - I have probably around 50 or so retro PCs. Imagine if I had to buy a new PSU for each one of them - I'd be broke already!
Also, you don't hear Xbox 360 owners massively dumping their old power bricks (PSUs) and getting new ones (that is, for those who still have a working 360, which not many are remaining - at least from the older models). Yet their power bricks rarely fail. Most of them are made either by... well... guess! - Delta, LiteON, and Chicony/HiPro.
And laptop owners? It's the same exact scenario.
Somehow people don't frown upon plugging in a 10+ year old laptop power adapter to their retro laptop. But with an ATX PSU, they are treated like it's some kind of a bomb about to go off.
I just don't get why people make this distinction / discrimination when it comes to power sources.
As for warranty, I can wipe my rear end with that more than half the time.
Last year I got a very modern 500W Seasonic PSU from the flea market on the cheap. I knew there had to be something wrong with it, as the stuff that ends on this flea market almost never works right / is there for a reason. So I opened it, and sure enough it was full of bad caps - every single one on the output, that is. The PSU was made in 2022. It still had a 5 year warranty. Luckily, I didn't know this so I recapped it and all was well. But then I did some research on the matter about what I could have done had I wanted to use the warranty. Short answer: even if Seasonic would honor the warranty (despite the fact that I don't have a receipt for the PSU, since I am not the original owner), I'd still have to pay shipping to send it to one of their "repair centers" (aka exchange depots), where I'd likely just get another unit with the same crappy caps back, but just not failed yet. Or maybe, if I'm really lucky, I'd get a refurbished unit from them, where they had a newer revision of the PSU with better caps - but I seriously doubt that. These days, big manufacturers don't have the time and don't want to spend the cash to hire techs to fix warranty units. They just send you a new/replacement unit if the old one has failed under warranty, and that's all.
Well, I say 'no, thanks' to that. Not only is this a waste of time and money for me (to have the broken PSU sent to some warranty depot), but it also does not address the original problem. So with that said, I am glad I didn't know the PSU had a warranty and that I just elected to recap it myself.
Reply 110 of 263, by shevalier
momaka wrote on 2026-05-07, 20:01:
You're probably right, judging by the phase configuration of the primary transformer.
About 15 years ago, I tinkered with the same OEM Hipro unit—without a clear schematic—and I really didn't like it. Overall, for this power range, I prefer the classic half-bridge topology.
this.
It produces the same high-voltage spikes as a flyback topology, but lacks “built-in short-circuit protection via power limiting.”
I’d buy the inventor of the Two-Switch Forward a beer
If the new power supply burned out, you went and replaced it under warranty.
As for the old one—you wrote yourself: “Well, it’s not that complicated. Spot the differences between flyback and SFT topologies. Replace the switches and electrolytic capacitors, and lubricate the fans.”
Of course, any retro computer enthusiast will learn to solder sooner or later, unless he’s a Saudi prince.
Reply 111 of 263, by tehsiggi
Speaking of old supplies.. I just went through the bay and looked for some.
The attachment DSCN0006_800x800.JPG is no longer available
Look at this Codegen one.. the maths do not math on this one at all. I'm waiting on the 520W variant to arrive which has 42A on 5V - for some project. Re-cap worth for sure..
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 112 of 263, by shevalier
tehsiggi wrote on 2026-05-15, 15:28:
Oh, and when it arrives, could you post a photo of the +3.3V linear regulator on the MOSFET?
It was present in half of the Codegen power supplies 😀
Reply 113 of 263, by tehsiggi
shevalier wrote on 2026-05-15, 15:44:
You mean like this?
https://www.eevblog.com/forum/general-computi … y-in-the-world/
Reply 114 of 263, by lti
I remember another EEVblog thread where someone got a power supply that was missing its heatsinks about 10-15 years ago.
Reply 115 of 263, by shevalier
tehsiggi wrote on 2026-05-15, 16:57:
You mean like this?
yep.
I’ve had to deal with a Codegen like that before.
It all ended up with me having to wind an extra winding for +3.3V on the transformer, fit diodes instead of the MOSFET, and route part of the group stabilisation choke windings to the +3.3V channel.
It actually worked, and not badly at all. For a P4-based system where there is no direct use of the +3.3V voltage from the PSU.
Ever since then, whenever I hear “Codegen”, I get the shivers.
They had two platforms that were sold under the same model name.
Reply 116 of 263, by tehsiggi
So the PSU arrived. Good news? It's in one piece and is not using a linear regulator to get from 5V to 3.3V by the looks of it.
The attachment out1.jpeg is no longer available
The attachment out2.jpeg is no longer available
However, the spec sticker is a whole lie. The output rails use 2x s30d40c - one for 5V and one for 3.3V - those are rated at 30 amps each. Not 30A per diode inside them, but 30A for both diodes together. The 5V rail with it's rated 42A is a blatant lie. Same for the 12V - it's spec'ed at 24A - uses an F16C20C - 16A for both diodes together. That's far from the rated 24A.
The attachment type.jpeg is no longer available
For my purpose it does not really matter, I'll re-cap the PSU and be happy. Even if I can get 25A out of the 5V rail I'm already happy. It's not a 12V centric PSU, that's all that really mattered for me. And it's not like the russian reviews I found for these units didn't tell already that this is basically a fraud 😁
Reply 117 of 263, by shevalier
tehsiggi wrote on 2026-05-18, 18:06:
This is Codegen way
And a transformer with the same markings as their 350-watt model.
It is clear that the transistors are not of the D209L (or their 12 A equivalents, which are used in 450–500 W models), and the input capacitors do not have a capacitance of 1000 μF / 2 = 500 W.
In all likelihood, their capacitance does not even reach 820 μF.
Reply 118 of 263, by momaka
shevalier wrote on 2026-05-08, 06:13:
I'm the other way around - I always prefer forward converter topologies due to the fact that they react much quicker in case of a short-circuit on the output (due to more precise OPP on the primary). This is actually really important when I test motherboards or video cards where I had to do MOSFET replacement. If there is anything wrong with the driver or PWM controller circuit on the video card / motherboard, it's important for the PSU to shut down quickly to prevent possibly further damage. Also, when testing a motherboard that I had to do MOSFET replacement on, I usually pick a lower wattage PSU so that, again, it will shut down quicker in case something isn't right.
Half-bridge not only has imprecise OPP, but some designs often won't even latch off and continue to try to power-cycle / turn On after shutting down. This can cause constant power-up power-down cycling and do damage to other components.
And lastly, half-bridge can easily blow its primary side BJTs during extended brownout conditions if the OPP is not set very well (and for many PSUs, especially the cheapo units, it's not). For forward topologies, this is much harder to do, unless the manufacturer goofed up and really messed up on the calculations for the OPP.
Not quite.
STF almost never lacks protection via power limiting, as the PWM IC is on the primary side and provides pulse-by-pulse current limiting.
Also, STF does not have the same "very quick" and high voltage back-EMF spikes (i.e. high amplitude, short duration impulse) that flyback topology does. That's why the switching transistor for flyback usually has to be rated for very high voltage (typically 600+V), whereas for STF, it can be lower.
In any case, the snubber still needs to grow really quickly for designs past 300-350 Watts... hence why it's not so practical for higher powers.
Yeah, well, not always the case.
I mean if it's a local store and they can just take it back and exchange for another unit, then fine. But if it has to be shipped out, I've seen manufacturers make the buyer pay for the shipping to the warranty center. If that's the case, forget it - it will probably be cheaper to buy another PSU.
shevalier wrote on 2026-05-16, 04:55:
So you created a 3.3V rail with no regulation directly from the main transformer? If yes, that's really the least optimal way to do it. I've actually seen only a couple of very cheap/nasty PSUs use such design, and they did absolutely terrible on any cross-loading tests.
Here's one I looked at some years ago:
https://www.badcaps.net/forum/troubleshooting … g-inline-images
Actually on that one, the 3.3V rail didn't do too badly, so long as the 5V rail was loaded down nicely and consistently (like from a low-power Athlon or PII/3 system.)
But with a more modern system, even with low power draw (but majority of it from the 12V rail nonetheless), the 3.3V rail went way too high (above 3.5V). Likewise, with a very heavy 5V power draw, the 3.3V rail again became high. And if loading down the 3.3V rail by itself, it sagged really badly (barely 3V.)
So yeah, having an ATX PSU where all of the outputs are group-regulated together is not a good idea - not unless you really build the PSU to power a specific system where you know what all of the power draws will be.
Inherently, there is nothing wrong with a linear 3.3V rail. Its only downside is that it's more (very) inefficient, especially if down-regulating from the 5V rail... and for the majority of PSUs out there that do/did have a linear 3.3V rail, this is how it's done indeed. So for losses, you have:
P_loss = (5V - 3.3V ) x I_3v3load
If for example, the load on 3.3V rail is 10 Amps, then the losses (as heat) in the MOSFET are 1.7V x 10 Amps = 17 Watts... which is quite a bit!
Compare that to a mag-amp, where for the same load, you just have a (Schottky) rectifier loss plus maybe a 1-3 Watts in the saturation toroid core... so about 0.5V x 10 Amps, or 5 Watts in the rectifier + 2 to 3 Watts in the saturation coil, totaling about 7-8 Watts - about half of that of the linear regulator.
But on the positive side, those linear 3.3V regulator circuits are super quiet on the output, regardless of their load. Even with terribly degraded caps, they will still regulate OK. Only if the 5V rail becomes unstable, that's when the 3.3V linear reg circuit can also refuse to work or become really noisy.
Now, HiPro did do it a little better in their PSUs - they generated a separate "high 3.3V" rail that was under 4V generally and then used a MOSFET to down-regulate to 3.3V. As such, the losses in the MOSFET were much lower since it now has to drop only 0.7V max, if even that. So for the same 10 Amp load, it would have a Schottky rectifier power loss (about 5 Watts for 10 Amps) + a much reduced MOSFET power loss (0.7V x 10 Amp, at most)... totalling about 12 Watts. Those losses are still obviously worse than a mag-amp regulator circuit, but they are also much improved compared to a "straight 5V to 3.3V) linear regulation implementation.
The other advantage of a linear 3.3V rail circuit is that it needs no load to regulate properly... if done right, of course (I did encounter a Sun Pro -built Raidmax PSU before where this wasn't the case and the 3.3V rail was usually too high most of the time... unless it was loaded - then it sagged badly 🤣 .) With mag-amp 3.3V, a constant minimum load may be needed to keep it stable/operating within range. It all depends for what loads the 3.3V rail was designed for. For older 3.3 & 5V-heavy PCs, the 3.3V rail was designed for greater loads and thus it may not do to well without any load (often the case with the older half-bridge -based FSP PSUs, which is why they always put those big load resistors on the output voltage rails.)
Yeah, that's standard for cheapo PSUs (Codegen included), as shevalier noted.
It's indeed not that bad of a PSU, the lying label aside.
You've got 30 Amp rectifiers for the 3.3V and 5V rail, and they are in the larger TO-247 case.
Likewise, the primary BJTs are in TO-3P case, so they will definitely be better than the standard E13007 affair that most other cheapo PSUs used at the time - basically guaranteed up to 300 Watts continuous load (though I wouldn't try pushing them more.) The main transformer also appears to be sized approprietly, certainly enough to sustain those 300 Watts (and likely 350W peak), which should be plenty for any old retro 5V-heavy PC.
And hey, you've even got a PPFC inductor! The manufacturer had to sacrifice "wasting" copper there for you 🤣.
The only thing that possibly looks a little worrisome is the output side - particularly the side of the output toroid and the filtering caps after it.
To me, that toroid appears to be "106" size (about 2.5 cm dia. core) vs the larger "130" core (about 3.3 cm dia.) And it's Micrometals -26 type (yellow core with one side painted white), which is more lossy than -52 type core (light green with one side painted blue). As such, I think the maximum continuous load on the 5V rail should generally be kept under 20 Amps... which again, should be plenty for an old system. The PSU may be capable of outputting more, but for PSUs with T106-26 output toroid cores, I find that output toroid will often start running very very hot. For good longevity of the core, it's better to not run it too hot.
Also, you may or may not be able to do 20 Amps on the 5V rail if the output caps are not "up to snuff". Generally, the 5V rail should have at least 2x 2200 uF caps and a PI coil / bobbin inductor between them if you want to pull anything close to 20 Amps without the ripple becoming a problem. Increase capacity one notch up for 25-30 Amps (so 2x 2700-3300 uF). This is where many cheapo PSUs cut corners and either don't install big enough output capacitors or use only one or don't include a "PI" coil/bobbin inductor. Any of these (but especially the missing PI coil) can result in much higher output ripple.
The reason I mention this is because when you do the recap, you should see what the PSU has (in terms of capacity for the capacitors), but not go below the minimum capacity mentioned above. I've often seen some cheapo PSUs put only 2x 1000 uF caps on the 5V rail, and that is absolutely no good for a 5V-heavy PC.
Same goes for the 3.3V rail.
For the 12V rail, at least one 1500 uF cap will generally get the job done for a not-12V-heavy PC.
There's generally no penalty for going with higher capacitance (even if doubling it), but sometimes there is for going too low with the ESR (certain older PSUs like this may oscillate very badly with caps with too low ESR.) Therefore, DO NOT use polymers. For old half-bridge topology like this, entry-level low ESR is more than fine. The switching frequency is fairly low, so it's really the capacitance that starts to matter more here.
shevalier wrote on 2026-05-18, 18:30:
Well, the transformer is -proper- "35" size, at least (35 mm across the top and at least 40 mm tall). I've seen worst in L&C PSUs, where the transformer says ERL35, but it really is a 33-sized one... and about 1 cm shorter.
For oldschool half bridge PSUs like this (i.e. relatively low switching frequency), ERL35 is usually good for about 300-350 Watts max. Beyond that, BJTs tend to blow up (even if they are much bigger), because the core can saturate.
With that said, no need for very big input caps anyways. If the PSU is only realistically capable of 300-350 Watts max (which I think is the case here with tehsiggi's PSU), 2x 560-680 uF input caps should be perfectly adequate.
Reply 119 of 263, by shevalier
momaka wrote on 2026-05-19, 14:05:
Because in the original Delta (or DTK? Whoever made the first classic half-bridge AT, which everyone then started copying), protection was based on the base current of the transistors rather than a current transformer in the primary circuit of the main transformer.
I may have got the number of turns spot on, but the voltages were within 3.3 ±0.15 V.
Which is terrible for SDRAM and the corresponding chipsets.
For newer systems, well, that’s problem of the voltage regulators on the motherboard. 😀
