Reply 100 of 231, by MagefromAntares
- Member
PC Hoarder Patrol wrote on 2026-06-05, 12:31:MagefromAntares wrote on 2026-06-05, 12:26:PC Hoarder Patrol wrote on 2026-06-05, 12:23:Kinda looks SFX to me...check the centre hole spacings to see (as measured against one of my SilverStone models)
According to the manufacturers website this is definitely larger than SFX:https://www.fsp-group.com/en/product/pcpsu/14 … 235198-107.html
I'm referring to the Hipro (as pictured) rather than the FSP
Sorry I misunderstood.
To DustyShinigami: If you measure the PSU and it is of standard SFX size then you can check if the mounting bracket of that PSU can be removed(It seems to be not from the pics, but maybe?) because then it could be reused for a more powerful SFX PSU that can provide the required wattages.
"A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it." - Dune
