Yes, the only exeption at that time was the 440BX (of course I am aware of the older sister of my config, the Abit BP6), the way it could be cranked up so high really startled me when realizig it were the Celerons that ran on it (celerons with the cache, not their L2less older brothers, were basically at the same level of overclockability to my experiences), and you're right, the 815 was a quite fail with that mem. limit.
Nforce2 RULEZ! There is no objection to this marvelous miracle of the AthlonXP ages. I really loved it, though never played with it. Instead, I have a lot experiences with the shitty KT333 and KT600, both unable to run at 400FSB (only with the RAMs from the recommendation list), anyways it was a low competitor against the nVidia's solution.
KT800 and 880 are a very good chips, will run stable at 800fsb no matter what. To conclude you, I absolutely agree with the slow southbridge performance, but this can be of course fixed using own PCI SATA add-on card, no? ( nowadays ) 😅
VIA wasn't that bad in the KT133 era, it provided a cheap solution, but from the technological point of view, it is a white knight - it came as a cheap and sufficient solution (and just in time), supporting both Intel and AMD CPUs instead of expensive chipsets of these two gigants. Applause !!!
MOBO: PVI-486SP3 Rev 1.2
CPU: POD-83
RAM: 2x16MB
VIDEO: Matrox Millenium 2MB/Voodoo2 12MB/Video Blaster VT300
AUDIO: SB Vibra16 FM
SCSI: 72GB 15k RPM HDD/YAMAHA CD-RW 16x/ZIP drive + FDD drive
NIC: 3Com Etherlink III
PSU: 230W Generic
OS: Win95 OSR2.5
