So a couple of updates, after installing the SCSI card, hard disk and cdrom on the Cyrix 120MHz system and installing Windows 95 I was suddenly having this weird mouse problem. Basically the mouse cursor appears all squashed and wont go any further down the screen than about half way. I had the exact same problem a few years ago messing about with the same Cyrix CPU and the same SCSI card in the Biostar MB8433, at the time I blamed it on branch prediction but it seems I jumped to the wrong conclusion.
Cursor miniaturization(squashed)
Right click where the cursor is located and the menu appears below.
I figured it MUST be the last change I made to the system! I ripped out the SCSI card, cdrom and hard disk and replaced it with IDE components and I couldn't believe it when I still had the same mouse problem!
NOTE: My 2 extra VOODOO2 cards arrived from Russia so I tested SLI mode while I had the system turned over to IDE: No FPS increase at all. I guess the CPU is completely bottlenecked.
I returned the SCSI components and turned off all Cyrix enhancements and the mouse cursor went back to normal, so one by one I tested each Cyrix enhancement and found it was LSSER=OFF causing my problems. I know from feipoa's thread that LSSER=OFF gives a substantial performance increase up to 8% in some applications and games. *frustrating*
I tested a few different serial mouse and still continued to have the problem.
Strangely Quake and everything ran fine, everything looked fine it was just this damn mouse cursor! Not being able to move the cursor past the half way point made things difficult.
Feipoa suggested I drop the CPU speed down to 100 MHz to make sure its not a frequency related stability issue or alternatively I could have popped a Cyrix 120MHz Stepping 0 Revision 5 CPU in but I did neither of those things. Somewhat fed up with tweaking after such a long time of stability I removed the Cyrix 120MHz CPU and installed a Pentium Overdrive at 83MHz.
I tested the POD at 100MHz in the UM8810 and I had a couple of crashes getting to the DOS prompt and trying to run speedsys.
I increased wait states, changed timings to 3,2,2,2 and tried again and got a little further but still had some crashes at the dos prompt.
POD back @ 83MHz 😀
I admit I didnt spend much time on attempting to OC the POD and I'm satisfied with that.
POD 83MHz + UM8810 + VOODOO 2
3Dbench 1.0c : 84.1
Pcpbench /vgamode : 22.5
Pcpbench 100 640x400 : 8.5
Pcpbench 103 800x600 : 5.3
Pcpbench 105 1024x768 : 3.8
Quake 1.06 SW : 21.3
GLQuake 0.98 800x600 : 33.9
The Quake + GLQuake score's are excellent but the DOS VGA and SVGA modes are lacking. Any application or game that depends on the ALU heavily is probably somewhat crippled by the POD @ 83MHz when comparing it to the Cyrix 120MHz and Cyrix 133MHz 5x86 CPU's.
