Reply 100 of 199, by FreddyV
8bitbubsy wrote on 2022-07-14, 11:26:So, does it make sense to use the new 286 driver on a 486DX4-100? Will it work and give faster speeds?
Even if Retro Eric answered 😀
I would like somebody to try, because in theory, it should work.
You may need to add a value in the delay.
In the 286 version of the driver, I did remove the delay function only where it was not necessary.
And the 286 code is the fastest possible (Even for 486)
The overall performance is of course limitted by the ISA Bus speed and we know it is not that fast.
