CVX4 : high quality covox adapter
Reply 100 of 484, by MobyGamer
Are you saying that there should be a single pin for one probe that, when the other probe touches the other pins, the value should be the same? Maybe I didn't understand, but I wasn't able to find a common pin where all other pins reported the same resistance.
Is there anything else I can do? I guess i could map out all 256 combinations, but gosh that would be a PITA...
Reply 101 of 484, by keropi
yes, if this is a "common resistor network" then there is a single common pin and when measured against the others you should get the same resistance. Have you tried in pairs? 1+2, 3+4 , 5+6 , etc
Maybe that's a special network with various resistances in it - hard to tell though without having the thing at hand...
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 102 of 484, by Scali
MobyGamer wrote:
Okay, here are all three of mine disassembled: […]
https://goo.gl/photos/PGaVfpzbvTYyTGdB6
https://goo.gl/photos/NYfmWroJ71xD32e97 # This is the one I recorded the reference video with
https://goo.gl/photos/MZzrVvLaJpD5waAe8
Great, many thanks for that!
I am surprised at Covox #2. Looks like they had all sorts of wild plans for the thing, judging by the room on the PCB for various components. But they aren't assembled here.
The other two seem to have virtually the same PCB, where no extra components can be put on.
I see that they wanted to put a 74HC30 on there. That's a bunch of NAND gates. And a HC05, that's a hex inverter.
Seems like they wanted to include some logic to respond to specific commands sent to the port...? Could this be similar functionality to the Disney Sound Source? That one was also made by Covox, wasn't it? Just branded as Disney?
Reply 103 of 484, by Great Hierophant
I think that Trixter's Covoxes correspond to figure #3 in the Covox patent, although figure 5 is also a possibility. Essentially you have a resistor network summed with resistors. Pins 1-8 of that package are connected to D0-D7 of the parallel port, pin 9 & 11 give signal and ground (not sure which is which) to the jack and pin 10 goes to one of the parallel port grounds.
Reply 104 of 484, by Beegle
Hmmm. But would a resistor network have the Covox logo on it? Isn't that a standard thing that we can buy in an electronics store?
My guess is that it's something more custom-made than that. But that's just a guess.
Also funny thing is that I also have two Speech Thing versions. One beige with the two wires (3.5mm and 2.5mm) as seen in the video, and another chrome one with only the 3.5mm.
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Reply 105 of 484, by stamasd
I feel like Christmas is back again. I just went to get today's mail, and found a package from Belgium. I thought "that's the CVX-2 from Serge" but I was wrong.
It was 2 kits! One SMD, and one through-hole. Wow!
I'm too drunk now to do any SMD soldering, and besides in 2h I'm leaving for a New Year's party. But my soldering station is warming up, and I'll put together the regular through-hole tonight.
Thank you Serge for the kits, and the greeting card. I'll surely test them in the next day or two. I'm not great at making videos (in fact I have only 1 youtube video in the past 10 years: https://www.youtube.com/watch?v=oNz5cLAw4ZM ) but I'll do my best.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 107 of 484, by Jepael
It is custom labeled R2R DAC network, so in theory armed with info how R2R networks should look like, it is possible to determine the resistances.
So between any two data pins, you should find 2R+R+2R.
Between output and most significant data bit (D7, LPT pin #9), there should be 2R.
Between ground and least significant data bit (D0, LPT pin #2), there should be 2R+2R.
Or just buy one of these, with say 10k and 20k resistances :https://www.bourns.com/pdfs/r2r.pdf
Although, the Covox patents say the resistances should be R=100k, 2R=200k, but to attenuate the audio from 5V levels to audio levels, the output to ground resistance is 15k. Capacitance about 0.005 microfarads, so I suspect 4.7nF, resulting into about 3000 Hz low pass filter bandwith.
Edit:
OK, it does not completely add up. 15k in parallel with 100k R2R output impedance is about 13k, and 13k with 4.7nF is already 2600 Hz low pass filter.
Also a slight point to note is that the in the patent schematics, the R2R network's least significant bit's side is not connected to GND through 2R. In theory it should, in practice it most likely makes little difference regarding the sound quality.
Reply 108 of 484, by Great Hierophant
keropi wrote:
@Beegle yes it could be a covox-specific network maybe with some different values […]
@Beegle
@GH
where are these patents located?
Trixter linked to it on page 4 of this thread :
https://www.google.com/patents/US4812847
Reply 110 of 484, by dreamblaster
MobyGamer wrote:
Okay, here are all three of mine disassembled: https://goo.gl/photos/PGaVfpzbvTYyTGdB6 https://goo.gl/photos/NYfmWroJ71xD32e97 […]
Let me know if the pictures don't show up. While the middle one has a more complicated board, all three appear to use the same resistor package.
THANKS!
on covox nr 1 and 3, the 'black pack' has 11 pins.
on covox nr 2 (which you recorded), the pack has 10 pins!
So they sure are different.
Do they all sound the same ?
Thanks for your support !
Reply 111 of 484, by MobyGamer
I tried, but maybe I was doing something wrong. Here's a quick video of what I was seeing (sorry for poor quality): https://youtu.be/Zl9LL2n6n3I
Let me know if there's anything else I can do. (Should I attempt what Jepael wrote?)
Reply 112 of 484, by MobyGamer
I was afraid you were going to ask me that 😀 I haven't tried. I will make a recording of Crystal Dream using one of the 11-pin pack versions in the next 24 hours.
Reply 113 of 484, by dreamblaster
thanks for the sacrifices !!, I have sent you a pm, by the way.
Reply 114 of 484, by keropi
I can't really understand atm these readings, what it strikes me as odd is that we are getting reading on the 500k~700k ohm range... isn't that too much?
Maybe someone else has a better idea how to crack this.
Reply 115 of 484, by gdjacobs
That seems high unless it's designed for a ridiculous input impedance on your preamp.
Reply 116 of 484, by MobyGamer
When I recorded the first reference, the output was low and I had to add +20db gain.
Reply 117 of 484, by Great Hierophant
With the 10-pin package, the two pins on the end seem to go to the audio jack. If that is so, one pin is used for the audio signal and one pin is used for ground. Using your multimeter in continuity mode, you can determine which pin is which by seeing which pin goes to the tip (signal) and which goes to the sleeve (ground). Ideally you should be putting one end of your multimeter on the signal out and the other end on your data pin.
This article describes the workings of a Covox very well. http://kb.gr8bit.ru/GR8BIT-KB0010-Adding-mult … ce-23102013.pdf
It seems that all Covox type devices use two kinds of resistors, with one set double the resistance value of the other set. Perhaps because a resistor ladder package is used, all the resistive elements within that package share the same tolerances.
Reply 118 of 484, by James-F
Might be transistors between the pins that add 300k-500k to the measurement.
Reply 119 of 484, by MobyGamer
dreamblaster wrote:
on covox nr 1 and 3, the 'black pack' has 11 pins. on covox nr 2 (which you recorded), the pack has 10 pins! So they sure are d […]
Well, I did some re-recording tonight with Crystal Dream: One on the 10-pin device (same device used as before), and another on the 11-pin version:
ftp://ftp.oldskool.org/pub/drivers/Covox/Spee … al%20Dream.flac
You will notice one second of silence in the beginning of each file; this was done deliberately to illustrate the noise level. The 486 I was using last night died 😒 so I pulled out a Pentium Pro, and unfortunately there is some noise when I connect to this system, so I included noise for comparison. The 10-pin device has less "ambient" noise, if that makes sense.
They sound similar to me, but I think the 10-pin one has a slight edge in quality because it is less noisy.
I will determine which pin in the 10-pin version is ground and output (thanks GH) and then I will try to use that information to determine what 2R is (thanks Jepael), and that should hopefully solve the mystery of why the 10-pin version sounds so good? But not for another 10-12 hours, because Happy New Year 😉
