AMD K6 Quake2 and Quake 3, aiming for stars.
Reply 100 of 169, by Necrodude
A little small update.
I have uploaded a reworked patch.
Here is the latest patch
https://1drv.ms/u/s!AnRnGWN7nMe4iWqynzngjLC6Is6Y?e=owg8gP
Installation:
Just drag and drop the files in your quake3 folder. You will by default have the "Ultra fast version" aka Fast and ugly.
If the game for some reason decides not to start. Try another config file. Remember, if you try this, also delete the q3config.cfg file in your baseq3 folder.
The autoexec file writes to the q3config file.
The default autoexec config file is the fastest.
This patch is also modular. You can amongst other choose if you want compressed faster textures or Fast ultra low quality sounds.
In the Baseq3 folder and you will find different pak files. You will find the following files:
pak9 - map animations This file turns of all the moving stuff on the maps.
pak9 - sounds This file includes low quality faster sounds.
pak9 - texures This file includes compressed faster textures.
pak9 - GFX This file includes compressed explosion effects etc.
If you dont want compressed textures or sounds, or any of the stuff, just remove the pak files you want.
This Patch also includes @G3Virus (Patrik A) exe with SMP support , (this SMP support comes from a plugin dll file. Its not the same as R_smp "1").
"Low Quality Audio" support is also added into the game menu.
Different speed configs are also included
You can choose from "Super fast and super ugly" to fast and good looking.
This patch will most of the time Quadruple Quake3:s FPS count.
Reply 101 of 169, by Skalabala
Thanks for doing this 😀
Reply 102 of 169, by Skalabala
Playing with game configs is cool, especially if it can make a game more playable on AMD K6.
I want to get serious sam and return to castle wolfenstien run better.
Reply 103 of 169, by Necrodude
Skalabala wrote on 2023-04-03, 18:10:
You can use these configs on wolfenstein (and most other id3 engine games). But you need to delete the Quake3 specifik stuff like skins, and you probably want to have cg_drawGun at 1. If you google a bit you will find that wolfenstein has some newer cvars that also can increase performace. If I recall correct one of them was called "wolfparticles"
Reply 106 of 169, by Necrodude
rasz_pl wrote on 2023-04-03, 23:14:
Did anyone happen to record a quick video of Q3 optimized this way?
The game would look something like this:
https://www.youtube.com/watch?v=MdTj4rpaxm8&t=92s
Dont forget that you can make the game look almost like vanilla Quake with one of the config files,
but you cant do that in tandem with the pak9texture.pk3 file.
Reply 108 of 169, by dj_pirtu
I think I'll build a K6-III+ system with VIA MVP3 1MB L2 cache and Geforce 2 GTS (and maybe V2 SLI on side) and test how much I can get...
Edit:
Soyo 5EMA+
K6-III+/560 (5x112FSB)
GF2GTS
256MB RAM
WIN98SE, no sound, tightest bios settings, Detonator 8.05, without optional pak-files and quality.cfg
~130fps
Not bad from the ~43fps which I got without any tweaks.
Reply 109 of 169, by Necrodude
Not bad! Not bad. I am getting around 130-140 isch. With the Quality cfg as well. But this is with sound on my k6-3+ 400@616mhz with my gf2 Ti
WIth the absolute fastest settings and fastest pak files/cfg I get 206 FPS.
Reply 110 of 169, by Skalabala
Did some playing around again 😁
I got 142.2FPS with untouched Quake 2.
Reply 111 of 169, by noshutdown
with k6-3+550, geforce2ultra and windows2000, i got 68fps in quake2, and 6.5fps in quake3, both with 640*480 medium quality, that seems horrible.
Reply 112 of 169, by Skalabala
Got my Quake 2 now at 160FPs 1024x768 with my K6-3+ Still with stock game files.
Reply 113 of 169, by Skalabala
noshutdown wrote on 2024-11-01, 03:54:
If you use Win98 and Geforce 2 with Driver 7.76 to 12.46 then it will be way faster.
Reply 114 of 169, by The Serpent Rider
Well, 6.5 fps is definitely not right. Even my overclocked 486 is faster than that in Quake 3.
Reply 115 of 169, by Necrodude
My best on Quake2 with my K6-3+ 400@616 on a Geforce2 GTS with my max tweaked Quake2 is 168 frames per second.
On Quake3 I got 212 frames per second. That with using the patch posted above.
Reply 116 of 169, by Necrodude
Skalabala wrote on 2024-11-01, 23:01:
Not bad! Not bad at all.
Reply 117 of 169, by marxveix
Gun is removed from one of my autoexec.cfg, what is the code change to get gun visible? set cl_gun "1" does not work.
set cl_footsteps "1"
set cl_gun "0"
set cl_lights "0"
set cl_predict "0"
set cl_particles "0"
set gl_triplebuffer "1"
set gl_ext_swapinterval "1"
set gl_swapinterval "0"
set gl_dynamic "0"
set gl_polyblend "0"
set gl_flashblend "0"
set gl_texturemode "gl_linear_mipmap_nearest"
set flushmap "1"
set gl_round_down "1"
set gl_ztrick "1"
set gl_modulate "1.2"
set gl_ext_palettedtexture "1"
set gl_ext_compiled_vertex_array "0"
set gl_playermip "0"
set gl_picmip "0.8"
set m_filter "0"
set cd_nocd "1"
set in_joystick "0"
set cl_fov "85"
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 118 of 169, by marxveix
marxveix wrote on 2025-11-05, 14:24:
Gun is removed from one of my autoexec.cfg, what is the code change to get gun visible? set cl_gun "1" does not work. […]
set cl_gun "0"
set cl_lights "0"
set cl_predict "0"
set gl_dynamic "0"
set flushmap "1"
set gl_ztrick "1"
set gl_picmip "0.8"
set m_filter "0"
set cd_nocd "1"
set in_joystick "0"
set cl_fov "85"
hand 0 was missing.
Reply 119 of 169, by MattRocks
As this started as a AMD K6-3 thread I'll throw my pennies in.
I don't have any K6 with me to prove it but assuming IIRC, I left my K6-2 configured for Quake3 after discovering a passively cooled Radeon 9xxx outperformed an actively cooled GeForce 3. That may have been because there were ATI Radeon drivers optimised for AMD K6-3 3DNow. I think the driver version to hunt is "6071" before Catalyst etc. NVidia didn't try as hard.
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i7) ] * lost
