Mortal Kombat II problems
Reply 100 of 110, by BliggyBlop
Update: I used a combination of the Archive drivers I found and the drivers you can install in Windows to successfully install the drivers. However, I get no sound through the sound card.
The bliggiest blop.
Reply 101 of 110, by darry
BliggyBlop wrote on 2020-06-03, 20:57:
No sound even in Windows ?
I assume you have checked mixer settings and possibly tried line out and speaker out on your card (if it has both) ?
Reply 102 of 110, by darry
This Windows driver (the one you linked) should work under Windows 9x http://www.vogonsdrivers.com/getfile.php?file … 178&menustate=0 .
If the driver is properly installed but you are not getting sound with the mixer out enabled and the speakers/headphones connected to the green jack ( https://web.archive.org/web/19971009081451/ht … pci/a_specs.htm ) , you may have a defective/damaged card .
If sound does not work in Windows, it is unlikely to work in DOS .
For DOS , this one should work :
http://vogonsdrivers.com/getfile.php?fileid=3 … menustate=45,36
As a plan B, there is this one for DOS, but it does not explicitly mention the ES1370, so I have my doubts :
http://vogonsdrivers.com/getfile.php?fileid=3 … menustate=43,36
Reply 103 of 110, by BliggyBlop
Doesn’t look like it will work, unfortunately. There’s a readme file inside, and it says what chipsets the driver supports, and it doesn’t say 1370.
The bliggiest blop.
Reply 105 of 110, by BliggyBlop
Oh, wait! I just saw the other link for DOS drivers. I’ll try those.
The bliggiest blop.
Reply 106 of 110, by BliggyBlop
I tried the DOS drivers. They give me this error message:
error: PCI device detect failed: Device not found.
PCI audio driver NOT loading.
The bliggiest blop.
Reply 107 of 110, by darry
BliggyBlop wrote on 2020-06-04, 20:41:
That is not cool .
Does the card work in Windows, at least ?
It may be defective, but that would be really bad luck .
Reply 108 of 110, by BliggyBlop
It doesn’t work in either.
The bliggiest blop.
Reply 109 of 110, by darry
I have just thought of something . When you were testing the CS4280, did you ever try letting Windows boot fully and then choosing "restart in MS-DOS mode" to exit to DOS ?
It's a long shot, but maybe the Windows driver for the CS42080 would initialize it just enough for the DOS utility to then detect the card and work .
Reply 110 of 110, by darry
A long shot, but setting PnP OS to NO in BIOS might be worth a try .
