Reply 100 of 734, by Eivind
- Oldbie
Update:
Got I2C communication code working, enabling configuration of the PWM-controlled fans.
Also did a bit of rework on the status LED situation, I'll now use an I2C-controlled MCU to drive a single RGB LED instead. That means we can setup standby- and power light intensity, patterns, etc in software / BIOS.
In addition, I thought about the HDD activity LED; my last prototype showed that only using the SD CMD signal didn't look particularly good, instead I'll try to hook into the BIOS control routines for reading and writing data to SD/USB/SATA and send activity signals to the MCU which will in turn control the RGB LED.
...and then it hit me, maybe I should try adding support for HDD clicking sounds as well, might be fun to try at least:
And here's the footprint for adding the D1 Mini - for Wifi/modem support:
Any other suggestions for improvements? I'm getting close to ordering the next batch.
