Reply 1000 of 1279, by wbc
ViTi95 wrote on 2024-05-30, 20:20:
* New VGA 320x100 executable. Uses same direct rendering method as vanilla Doom, but with half height resolution. High detail resolution is 320x100, low detail 160x100 and potato detail 80x100. Recommended for slow 386 cpu's with VGA cards. 2D elements also have half height resolution, so text is pretty much unreadable (unless someone creates a WAD with optimized fonts for this mode)
looks... interesting :)
by the way, i think is is possible (but requires a fair number of effort) to simulate a raster interrupt which will switch to full 320x200 mode at the moment bottom HUD is displayed - I've experimented with that trick by polling for port 0x3DA, and toggling the doublescan bit in CRTC, and this seems to work on most VGA cards except NVidia.
--wbcbz7
Reply 1001 of 1279, by ViTi95
I've done some font work and now I think FastDoom 320x100 modes are much more usable. What do you think?
The attachment dos4gw_016.png is no longer available
The attachment dos4gw_017.png is no longer available
https://www.youtube.com/@viti95
Reply 1002 of 1279, by appiah4
It is actually legible. A lot more so than many handwritings I have to read daily.
Reply 1003 of 1279, by BitWrangler
So who has a Harris 25Mhz 286 with 8MB and wants to try it with a 386 emulator now? 🤣
(woe is me because I once had one and let it go)
Reply 1004 of 1279, by appiah4
I only have a 286-16 and I doubt that would be worth trying 😁
Reply 1005 of 1279, by Frenkel
*cough* Doom8088 *cough*
Reply 1006 of 1279, by vsharun
crazii wrote on 2024-02-15, 04:34:
Sorry that I didn't know the incompatibility problem until recent days, I've created a PR so FastDoom can work with HDPMI, and maybe for win9x too.
Yes it is unfortunately. On E5800 (3.2GHz Core2 Duo) w/Audigy2ZS/Creative DOS drivers 5.00 w/8Mb GS bank under DOS 7.1 from W98SE (no GUI boot, clean MS-DOS startup) I have following observations:
1. with latest jemmex + hdmpi32 -r, starts ok, after several demo loops - crash
2. with stock himem/emm386 noems novcpi and hdpmi32 -r - not enough extended memory (the same for hdpmi32 -r -x)
The only solution to run fastdoom - via jemmex and following crash after several minutes.
Vanilla ultimate doom have no issues, the same for quake dos/q2dos w/SSE support/original quake1/Duke Nukem 3D - all of them w/hdpmi32 -r host (= mtrrlfb provides speedup for dos4gw and cwsdpmi games under hdpmi32 host).
Reply 1007 of 1279, by 7F20
vsharun wrote on 2024-06-17, 15:10:
Why would you need to run FastDoom on a 3.2GHz processor from the 2000s? Serious question, it seems absurd to me. Like, wouldn't regular Doom run very fast anyway?
Reply 1008 of 1279, by vsharun
7F20 wrote on 2024-06-17, 21:40:
The initial goal was to find a platform which will outperform everything in Phil's chart (Q1/Doom). Then the goal was shifted to narrower one - the fastest DOS gaming platform possible with Ensoniq (Creative then up to A2ZS) native sound.
So doom's, actually if you stick them together then the difference is apparent:
1. fastdoom (now) has working VESA support, which vanilla doesn't - 1024x768 looks fantastic
2. fastdoom - really fast, 800+ fps on athlonXP 2.2GHz/ti4200
3. fastdoom has broad sound and music cards support, which vanilla hasn't (Soundscape)
So my approach to the fastdoom is yet another discipline - run doom as fast as possible on as fast as possible hardware while maintaining some constraints (sound and music from A2ZS and/or Ensoniq's ES1370-1373).
Reply 1009 of 1279, by ViTi95
@vsharun Is the crash happening on the 1024x768 modes? I think there is a bug somewhere that ends up crashing the game only in that mode, I still have to debug it. In that mode if you get close to a wall, the performance drops a lot, which shouldn't happen.
Reply 1010 of 1279, by vsharun
ViTi95 wrote on 2024-06-18, 09:25:
Hi.
Any VESA modes affected (both r/d), the same for fdoom13h, the same for fdoom vanilla.
Last crash was related to memory allocation for Z_something with latest jemmex and ext memory limit to 59Megs.
EMM386 with NOVCPI - any fdoom binaries will refuse to run with "not enough extended memory", despite 1.7 gigs available.
jemmex with novcpi - fd768d - runs ok for a while (low fps), 768r - hang after startup. They all ultimately crash. And I suppose it is sound card related somehow.
hdpmi32 -r host in all cases.
Reply 1011 of 1279, by BitWrangler
Does it do it with music off? does it do it only using FM music? Thinking that MIDI timing loops are something that gets everything crashing sooner or later as CPU speed scales.
Reply 1012 of 1279, by ViTi95
New release, FastDoom 0.9.9e!
Changelog:
* Fixed diminished lightning issues on high resolution VESA modes
* Fixed some 2D status bar and menus misalignements
* Fixed rendering corruption on VESA 386SX codepath
* Fixed MS-DOS 7 crash #187
* New fonts for 320x100 resultion modes (half height)
* Optimizations (C)
https://github.com/viti95/FastDoom/releases/d … Doom_0.9.9e.zip
Reply 1013 of 1279, by 7F20
vsharun wrote on 2024-06-18, 06:14:
The initial goal was to find a platform which will outperform everything in Phil's chart (Q1/Doom). Then the goal was shifted to […]
How does this approach compare to using ZDoom on a modern PC?
As in, what limitations are you trying to surmount with your current approach? Is it just the soundcard support for the specific, particular card you want to use, or are you just chasing framerates and FastDoom is able to pull ahead of ZDoom or something like that?
Reply 1014 of 1279, by BitWrangler
Yah 'coz if it's tryna train AIs to play doom at 2000fps so they can leverage the model to fly smart bullets through a keyhole, then we might have objections 🤣
Reply 1015 of 1279, by vsharun
BitWrangler wrote on 2024-06-18, 14:27:
all combinations sfx and music crashes, including both set to none.
Reply 1016 of 1279, by vsharun
7F20 wrote on 2024-06-18, 17:35:
Well, several constraints are involved:
1. only DOS
2. only PCI soundcards, Ensoniq/Creative with cleanest possible sound
3. maximum compatibility (Dune2 for example - jemmex with maxmem)
what platform will be the fastest one for doom/q1/q2/duke3d.
BitWrangler wrote on 2024-06-19, 04:02:
Understand your scepticism. Take it from another angle: I'm from Bucha district, entire village was under occupation with executions etc, now I have friends and relatives on front line and would like to keep my sanity with me by chasing some technical goals and bringing back memories where life was somewhat easy.
Reply 1017 of 1279, by ViTi95
Just wow @vsharun, I hope the situation gets better for you and Ukraine.
I'll test on faster / modern systems, there has been reports of FastDoom also crashing on Phenom machines, so maybe this is related. Maybe you can try latest release and see if it crashes in the same way.
Reply 1018 of 1279, by badmojo
ViTi95 wrote on 2024-06-18, 16:32:
This is sensational, thankyou to all involved. It looks and runs beautiful now - I love this port 👍
Reply 1019 of 1279, by vsharun
ViTi95 wrote on 2024-06-19, 20:45:
0.9.9e crashes:
Sound Blaster DSP 4.01
ADDR: 220, IRQ: 5, DMA LOW: 1, DMA HIGH: 5
D_CheckNetGame: Checking network game status.
S_Init: Setting up sound.
HU_Init: Setting up heads up display.
ST_Init: Init status bar.
DOS/32A run-time (6001): exception 0Eh
Identity: page fault at 0838:0041C279
Unrelocated crash address 1:00034269, error code pushed on stack 00000000
Module name: "C:\GAMES\FD099E\FDOOM13H.EXE", ProcessId=0000
========================================================================APP/32=
EFLAGS = 00010283 [00000010.10000011] CS:[EIP] = 0F BF 03 C7 44 24 0C 00 00 00
EAX = FFC0ED3C ESI = 004D66E1 DR6 = FFFF0FF0 SS:[ESP+00] = FFFF9C13
EBX = FFFFFFFF EDI = FFC0894F CR0 = 80000011 SS:[ESP+04] = 00000018
ECX = 00000000 EBP = 004E66D4 CR2 = FFFFFFFF SS:[ESP+08] = FFFFFFFF
EDX = 00006500 ESP = 004E6658 CR3 = 00018000 SS:[ESP+0C] = 00000018
CS: = 0838 Base=00000000 Limit=000FFFFF Gr=PAGE Seg=CODE/32bit Type=5 Acc=DF9B
DS: = 0830 Base=00000000 Limit=000FFFFF Gr=PAGE Seg=DATA/32bit Type=1 Acc=DF93
ES: = 0830 Base=00000000 Limit=000FFFFF Gr=PAGE Seg=DATA/32bit Type=1 Acc=DF93
SS: = 0830 Base=00000000 Limit=000FFFFF Gr=PAGE Seg=DATA/32bit Type=1 Acc=DF93
FS: = 0840 Base=00000000 Limit=000FFFFF Gr=PAGE Seg=DATA/32bit Type=1 Acc=DF93
GS: = 0058 Base=00010980 Limit=000FFFFF Gr=PAGE Seg=DATA/32bit Type=1 Acc=DF93
Identity: page fault at 0838:0042FF97
Unrelocated crash address 1:00047F87, error code pushed on stack 00000000
Module name: "C:\GAMES\FD099E\FDM768R.EXE", ProcessId=0000
EFLAGS = 00010286 [00000010.10000110] CS:[EIP] = 8A 84 3D 00 24 FE FF 49 8A 00
EAX = 004BD62F ESI = FFE9BF68 DR6 = FFFF0FF0 SS:[ESP+00] = FFD5BF68
EBX = 00000031 EDI = 00629EDC CR0 = 80000011 SS:[ESP+04] = FFE9BF68
ECX = FFFFFF69 EBP = 616D7800 CR2 = 61CE3ADC SS:[ESP+08] = 0099D144
EDX = 0048BD88 ESP = 00660E48 CR3 = 00018000 SS:[ESP+0C] = 0000024C
Can't reproduce crash with vanilla fdoom.exe 0.9.9e
Win98's himem/emm386 noems ram (with vcpi host)
audigy2zs creative 5.00 drivers as general MIDI (8M bank) and sound blaster as sfx.
