Reply 1040 of 1042, by PC@LIVE
- Oldbie
Update on the Terminator II with AMD DX4-100, the first impression was quite disappointing, maybe I understood why, entering the BIOS I saw that by default, the RAM times are more conservative, maybe because the RAMs at that time could be slow, and in this way it ensured compatibility with any RAM, so considering that I have a FSB 33 and 60 ns EDO RAM, from the BIOS I selected all the fastest settings (Fastest 2-1-1-1 0WS), I memorized them, and I redid the benches (including those of Phil's).
At startup, I notice that the PC is better, I have the doubt that now the L2 cache works, in fact it doesn't work yet ️, but a higher DOS startup speed is visible.
Even Phil's benches confirm a clear improvement, which was more or less what you could expect, so let's see the best scores, with slow and fast settings, AMD 486DX4-100 CPU:
1) 50.0 > 66.6 2) 49.1 > 64.8
3) 35.7 > 45.0 4) 10.4 > 12.6
5) 11.4 > 15.1 6) 4.6 > 6.0
A) 67.59 > 98.02 b) 28.07 > 36.20
C-e) 8.1 > 10.4 d) 3.8 > 4.8
K) 127.8 > 192.0 m) 180 > 201
N) which would be Speedsys 4.70, with the score of 37.24 obtained only with the fast settings, with the slow ones it could not work.
In addition to these I have done others, and they all show an improvement, but the L2 cache problem always remains to be solved, I think it would make even better scores, we will see later if there is a problem with the chips (failures?), or it is something else.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
