Reply 1100 of 1147, by nerd73
red-ray wrote on 2025-04-29, 00:50:
I expect the stepping would be D0 rather than 0, but most DX CPUs that don't have CPUID return D0 on NT, SX return C0 and the 486DX-25 SX308 is the only CPU for which I have seen B0, see Early 80486 in https://www.geoffchappell.com/studies/windows … pu/precpuid.htm, I wonder which i486 returns A0.
It's possible it *could* still be for some buggy 1989 i486, but I've seen A0 show up before on NT on Cyrix 486DLC/DRx2 CPUs on this very site, and it wouldn't surprise me if it was secretly some way to handle 386/486 hybrid CPUs given that the criteria for A0 involves a functioning ET bit.
Reply 1101 of 1147, by red-ray
nerd73 wrote on 2025-07-28, 20:49:
It's possible it could still be for some buggy 1989 i486, but I've seen A0 show up before on NT on Cyrix 486DLC/DRx2 CPUs on this very site, and it wouldn't surprise me if it was secretly some way to handle 386/486 hybrid CPUs given that the criteria for A0 involves a functioning ET bit.
Many things are possible and as for "I've seen A0 show up before on NT on Cyrix 486DLC/DRx2 CPUs on this very site" a link would be sensible.
I would like to see what the SIV Menu->Hardware->CPUID->CPU-0 panel reports for such CPUs as given they are Cyrix CPUs SIV should detect them as such as they should have DIR0.
Reply 1102 of 1147, by nerd73
red-ray wrote on 2025-07-29, 06:55:
Here you go: Re: Running Windows NT 4.0 on a Cyrix DLC/SXL/DRx2
Reply 1103 of 1147, by red-ray
nerd73 wrote on 2025-07-30, 16:28:
NScaleTransitModels wrote on 2021-04-01, 02:19:
It is possible to run NT 5.0 (2000 Beta) on a 486DLC. I've successfully installed Beta 2 Build 1906 on physical hardware. Here's […]
I've successfully installed Beta 2 Build 1906 on physical hardware. Here's the setup I used:
-FX-3000 motherboard
-TX486DLC/E-40GA
-Cyrix Fasmath CX-83D87-40-GP
Thank you, I can see 80486-A0 on the panel, now I just need to see what SIV reports on the Menu->Hardware->CPUID->CPU-0 panel .
I wonder what happens when no FPU is installed.
file.php?id=106611
Reply 1104 of 1147, by lolo799
Tested on an iBook G3/500
The attachment siv583b04-ibookG3b.jpg is no longer available
Reply 1105 of 1147, by red-ray
lolo799 wrote on 2025-08-11, 19:43:
Thank you, many things worked as I hoped, but I need to make a few small changes and once I have done this please will you try an updated SIV? I hope to have an updated test SIV some time tomorrow.
Exactly which model of PowerPC is it and what is the speed?
BTW I suspect the screen show will look better of you install the Tahoma font, it's available via Re: SIV support for 386/486/586 class CPUs and 3Dfx + Matrox GPUs
Reply 1106 of 1147, by lolo799
red-ray wrote on 2025-08-11, 20:25:
It's this one:
https://everymac.com/systems/apple/ibook/spec … /ibook_500.html
I'll keep NT4 on it for the time being, happy to do more tests.
I'll try the font but I can't take screenshots, only pictures of the screen (which starts suffering from vinegar syndrome).
Reply 1107 of 1147, by red-ray
lolo799 wrote on 2025-08-11, 20:57:
Oh!, is there no PrtSc key? For the SIV screens you can press [Copy] then paste the image into MS Paint.
On the [ Windows ] screen SIV reported "Hardware Abstraction Error No more data is available." which I have never seen before. On my PowerStack SIV reports HAL PowerPC HAL. There should be a sub-key below HKEY_LOCAL_MACHINE\HARDWARE\RESOURCEMAP\Hardware Abstraction Layer, is there? It would also be handy to see HKEY_LOCAL_MACHINE\HARDWARE\DESCRIPTION\System\CentralProcessor\0.
file.php?id=224862file.php?id=224861
What do the Windows NT Diagnostics report as the HAL?
Reply 1108 of 1147, by red-ray
Thank you for the link, I also found https://en.wikipedia.org/wiki/List_of_Mac_mod … PU_type#PowerPC which is handy. What I really need to know is what all the Family + Model numbers are, I plan to look for them tomorrow. I just found a list of PVR values.
I have just uploaded the SIV32P V5.83 Book-05 test SIV which should do rather better, please may I have new save files?
BTW for you you get files to/from the iBook? My PowerStack is networked, but I don't think your system is.
Reply 1109 of 1147, by lolo799
Your PowerStack is officially supported but NT4 is only working on Apple machines due to the work of https://github.com/Wack0/maciNTosh
USB isn't supported so no external keyboard, and neither is the ethernet chip.
MacOS doesn't use the printscreen key but some shortcut I can't remember at the moment, the Ibook keyboard is pretty sparse.
I use firewire target mode to get files from the iBook, and sometimes a cd-rw to copy files to it to avoid rebooting all the time.
Reply 1110 of 1147, by red-ray
lolo799 wrote on 2025-08-12, 16:48:
Thank you for the new save files and I am well aware you are using maciNTosh. Have you ever reported any bugs? I suspect I will have to as some things don't seem to be working in particular HalTranslateBusAddress(). I have added Menu->System->ACPI + PnP->HAL Translations which should show the issue with HalTranslateBusAddress(), on my system I get as below.
file.php?id=224906
I suspect it will report translation errors on your system, also notice that SIV now reports my GPU memory clock as I found and fixed an I/O Port access bug.
In general SIV did much better on your system and I have now fixed I/O Port access so please may I have new save files generated with SIV32P V5.83 Worm-05? They should contain [translation] so I don't need a screen shot.
After pondering PrtSc I wonder, do you feel should I add Menu->Edit->Copy Screen and/or rename Menu->Edit->Copy Bitmap to Menu->Edit->Copy Window?
Reply 1111 of 1147, by lolo799
red-ray wrote on 2025-08-12, 18:03:
Renaming the Copy button would be enough I think.
Reply 1112 of 1147, by red-ray
lolo799 wrote on 2025-08-12, 20:06:
Thank you, it's as I suspected it would be, HalTranslateBusAddress() is failing when I suspect it should not. Below you should see it's failing on your system, but is fine on my PowerStack.
file.php?id=224924
I have posted https://github.com/Wack0/maciNTosh/issues/63, fingers crossed for a fixed HAL.
While I wait I for a new HAL I will fix the L2 Cache information and look into on how to do the PowerPC version of RDTSC so SIV can report the correct CPU speed.
Reply 1113 of 1147, by red-ray
OK I have made the change in SIV V5.83 Beta-05. I have also finally found PAS.exe, the Motorola PowerPC assembler for Windows NT and added PowerPC TB (TSC) reading support so please may I have a screen shot of Menu->Hardware->CPU Detail->CPU Timers + new save files ?
SIV32P V5.83 Tick-05 should also report the correct L2 cache information, is it correct?
The reason that HalTranslateBusAddress() fails on Apple is that there is no ISA bus.
Reply 1114 of 1147, by lolo799
red-ray wrote on 2025-08-13, 17:20:
I was going to comment on the lack of ISA, yeah.
I'll test the new version when I can, in a week or 10 days from now.
Reply 1115 of 1147, by red-ray
lolo799 wrote on 2025-08-13, 18:08:
OK, SIV V5.83 Beta-06 is now released so please use that.
BTW It also has Menu->Edit->Copy Desktop, if you do SIV32P -AIOCTL you can also use Menu->File->Profile->Hotkeys to setup a hotkey.
Reply 1116 of 1147, by nali
I didn't know this software and discovered it today, while trying to get VEN and ID on a Win98 machine for a PCI card.
Great job !
Too bad I didn't know before 😀
I usually booted a Linux or a Win2k+ for this ...
Reply 1117 of 1147, by red-ray
nali wrote on 2025-08-17, 03:08:
It's good to know SIV helped. I designed SIV for Windows NT and later with the Windows 9x/Me support being less extensive, especially so for Windows 95.
Reply 1118 of 1147, by nali
red-ray wrote on 2025-08-17, 07:42:
I noted you mentioned Win2k+, by + do you mean the extended version that uses the Windows XP ACPI driver
I just mean VEN & ID became easy to find on Win2000 and over, so XP, 7, etc 😀
Reply 1119 of 1147, by lolo799
I didn't know this software and discovered it today, while trying to get VEN and ID on a Win98 machine for a PCI card. Great jo […]
Great job !
Msinfo32 should show the vendor and id values under Win98.
