Reply 1100 of 1131, by Minutemanqvs
- Member
PC@LIVE wrote on 2026-02-22, 13:02:Minutemanqvs wrote on 2026-02-21, 16:05:PC@LIVE wrote on 2026-02-21, 15:33:Following your instructions 🧭, I checked through datasheet the voltage regulator chip 😬, it seems to be very common in PC P3 and Athlon, well it seems that the initial problem, of failure to start, could be connected in some way to this IC, so the subsequent problem, could be due to the definitive breakage of this IC, or something connected to it.
I tell you that the problem could be another, but in my opinion, it's probably him who broke 😑, looking at the pdf file, I extracted an image, where you can see the individual PINs to what they are connected to, I don't know if you are equipped for removal and verification, that is, you have specific tools, but most are quite easy to verify, using a simple multimeter with diode test or in OHm 🕉.
Also from that image you can understand which PINs to check, clearly if you make suspicious readings, you could be close to identifying the problem.I will have a look at it tomorrow, I have a hot air gun since 4 days so it's absolutely time to do dangerous things to an innocent PCB! These components seem to be available easily on aliexpress for 2-3€ so it might be worth trying to replace it if I measure something suspicious. I'm doing this mostly for the fun of reviving the board, not that I really need it. And I also have a good coworker/friend equipped for micro-soldering under a microscope if everything goes wrong 😉
Interesting 🧐
Keep me updated on the progress and work you will do, I would like you to be able to fix it, I will cheer for you.
So I finally got a replacement SC1155CSW chip and yesterday I did the exchange on the K7T Pro 2. And...unfortunately no difference, so it wasn't the source of the problem despite it getting very hot. At this point I'm calling it a day, this board will go to the "for parts" bin. Really thanks for your guidance and support until now!
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
