Reply 1160 of 1161, by PC@LIVE
- Oldbie
I continue with the tests of the motherboards, but it is not the A-Trend ATC-2000, which is still at the top of the list of those to try, I tried instead an S.370 with Celeron 500 MHz, precisely an MSI MS6178 VER:1.0, Intel i810 chipset (unfortunately not i810E), the format is uATX with three PCI slots and an AMR, next to that AMR there is a second AMR called PTI, honestly it might look like a kind of AGP, in reality it is not!
To make a long story short, I installed a 16 MB SDRAM, a new battery and connected the ATX power supply and keyboard and monitor cables, in short, I gave power and it started!!!
The BIOS is AWARD, dated 05/12/1999, from the first BIOS screen you can read that the integrated VGA uses 1 MB of memory, maybe a little but for normal use it could be more than enough, unlike the i815 it cannot be disabled, but you could perhaps add a second PCI VGA, if the main one is not enough.
I've already made some benches, and soon I'll publish the results, I'll probably increase the RAM to 128 MB or more, regarding the CPU, I don't think it can be updated with Coppermine, but in this regard I have to do some investigations, maybe who knows, we'll see!
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
