Reply 1180 of 1747, by dr_st
- l33t
Not quite today, but some time ago I mustered courage to swap the Fn and Ctrl keys on my Thinkpad T16 Gen3 keyboard.
Historically, IBM/Lenovo laptops had Fn as the bottom leftmost and Ctrl to the right of it. This is backwards from most laptops, but I grew accustomed to it. For many years, Lenovo had offered the option to swap them in the BIOS, but only in the very recent generation did they change the default from Fn-Ctrl to Ctrl-Fn, and the keycaps to match. Having changed them to be Fn-Ctrl in the BIOS, I found that I press the correct key when not looking at the keyboard, and frequently get mixed up when looking at the keyboard, because the labels don't match.
Fortunately, they made the keycaps the same size now, so a swap is possible. I was a bit nervous, since I never removed and replaced keys on a chiclet keyboard, and I could not find specific instructions for this model. The underlying mechanism is quite easy to break. Fortunately, a generic video was good enough, and the trick of using a flathead screwdriver to hold down the mechanism while prying the key out was all that was needed.
This is how the keyboard looks now, and now it is consistent with every other Thinkpad I use, and I no longer get mixed up. 😀
