AB-BH6 CPU help
Reply 120 of 135, by shevalier
myne wrote on 2025-09-26, 08:27:
ok, so which bios is in the pic?
That's you attached a couple post higher
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 121 of 135, by shevalier
In fact, it might be worth checking the BIOSPatcher microcode (file Reall.cod) set using the MCE utility.
I'm not particularly knowledgeable about families and compatibility.
It looks like BIOSPatcher contains all the necessary microcode for Slot 1, possibly including the Pentium Pro. (It can be run on Slot 1 using the corresponding Slotket.)
This file can be used to modify the any Award BIOS for P3.
The required microcode is simply replaced in a hex editor (all microcodes have a fixed size).
They can be placed in any order.
Reply 122 of 135, by TheMysteriousGray
sunkindly wrote on 2025-09-26, 07:25:
I'm kinda curious if the working 933MHz CPU is SL448 (cB0) or SL4BV (cC0)...they're both 1.7V so that rules out the earlier discussion about voltage potentially being an issue...
The code on the side of the 933 is SL4BT and it indeed runs at 1.7V. The 866 is SL4BV and also runs at 1.7V, so voltage was in fact never the issue.
Reply 123 of 135, by sunkindly
TheMysteriousGray wrote on 2025-09-27, 04:09:
Hmm, between the two there's pretty much no difference other than the multiplier. Very strange, but I guess it just goes to show how unpredictable retro computing can be.
SUN85: NEC PC-8801mkIIMR
SUN92: Northgate Elegance | 386DX-25 | Orchid Fahrenheit 1280 | SB 1.0
SUN97: QDI Titanium IE | Pentium MMX 200MHz | Tseng ET6000 | SB 16
SUN00: ABIT BF6 | Pentium III 1.1GHz | 3dfx Voodoo3 3000 | AU8830
Reply 124 of 135, by TheMysteriousGray
Amen to that. I’m still trying to figure out this weird issue with Half-Life where I get random lag and the audio stutters and skips over itself. I thought it might be the sound card, especially since I don’t have any RAM upgrades for it, but this AWE64 Value works fine with the other games I have installed, including Deus Ex. Sound Blaster Lives are still dirt cheap, so I may try that to see if it fixes the issue, as well as getting a different graphics card. I hear Deus Ex runs much better in Glide than OpenGL or Direct3D, so I may cut the flesh and buy a Voodoo3 despite how horribly expensive they are now. Decisions, decisions…
Reply 125 of 135, by Hans Tork
Sorry once again for asking for help here. I might need to make a new thread. However I am trying to build a socket 370 build and have an Intel P3 SL3XY. My current mobo is a Abit VL-6 version 1. I updated the bios using an Xgecu T48 to 7k(also tried other bios). However all I get is the CPU fan starting up but no display on the monitor. I have tried several things like clearing CMOS battery. Also it runs for a long time but no display. Can anyone tell me if flashing this microcode will help? Is there any modified bios for VL-6 anywhere. Also what socket 370 is the most compatible for a Win 95 build. I tried Asus CUV 4x and the Abit Vl-6 and all of them have issues.
Edit: I have also tried the yz and 4k versions of the BIOS. There is actually conflcting info on the retro web and on other sites about which BIOS is indeed the latest.
i7/Titan X/X-Fi- XP
P4/X800/Audigy 2 ZS- W98
P3/Voodoo 3 3000/AWE 64 - W95
Reply 126 of 135, by H3nrik V!
Hans Tork wrote on 2025-09-27, 23:26:
To reach the greatest number of experienced vogoners, I'd definitely recommend a new thread 😀
Reply 127 of 135, by Hans Tork
H3nrik V! wrote on 2025-09-28, 21:29:
Probably right. However I got my answers on the Abit-Vl6 CPU thread. It seems my motherboard might have bad capacitors which are causing these issues. I will recap and update there if any progress is made.
i7/Titan X/X-Fi- XP
Reply 128 of 135, by NeoG_
TheMysteriousGray wrote on 2025-09-25, 22:33:
I may get a different mobo anyway in case something bad happens here, and will definitely get some PC133 RAM to see how far I can overclock it on this old board, but for now I’m just glad to know it worked!
I built an AB-BH6 rev1.0 system for a friend and went through this entire process already to try and get a 133FSB CPU running (I purchased a 1Ghz 133FSB PIII for it and modified a slotket). Unfortunately the rev1.0 board is missing a PCI divider that lets it run stable at 133, the onboard storage controller glitches out from overclocking the bus. The fastest I was able to get it run run at was 112Mhz resulting in an 840Mhz clock speed. The correct divider was introduced in rev1.1. It may be possible to retroactively add the setting to the BIOS but I suspect the hardware was also updated to support it.
P.S. Try looking at Japan for a Voodoo3, since prices on eBay were very high I bought a V3 2000 for $78USD there and used a proxy to ship it. Not bargain bin pricing but at least it didn't make me feel bad haha.
Reply 129 of 135, by TheMysteriousGray
NeoG_ wrote on 2025-09-29, 09:00:
Strange. I’ve seen people say this, but I’ve checked the manual for the 1.0 board and both BIOS I’ve used, and all of them mention/display that a 1/4 divider automatically kicks in for values at or around 133MHz. It’d be extremely strange and crappy if the manual was lying, so could the divider be faulty or flawed in design?
Also, very intriguing about looking at Japan for better prices. I presume using a VPN would help me in this situation?
Reply 130 of 135, by NeoG_
TheMysteriousGray wrote on 2025-09-29, 11:56:
I found manuals for the 1.0x and 1.1+ here: https://soggi.org/motherboards/abit/BH6.htm#manu
Only the 1.1+ manual mentions the divider at all (including 1/4) which is part of the base clock selection
In the 1.0 bios, the latest bios version shows the divider but no matter how high you set the clock it's stuck at 1/3. A Voodoo card will survive the AGP clock but the PCI is hopeless. I even tried a PCI ATA133 adapter in the hopes it would be more clock resistant but no luck, it was even worse. I was kind of disappointed because all the information I read indicated that on the BH6 133FSB was fine, but I didn't read about the rev1.0 board specifically until after. The system would post at 1Ghz@133FSB no problem but any attempt to use a storage device totally failed. It would boot at 124 but freeze at the desktop.
I used a proxy service, there are a few. Buyee, FromJapan, Zenmarket etc.
Reply 131 of 135, by H3nrik V!
My rev. 1.0 BH6 doesn't know other divider than 1/3 it seems. SS BIOS.
Reply 132 of 135, by shevalier
NeoG_ wrote on 2025-09-29, 12:46:
I found manuals for the 1.0x and 1.1+ here: https://soggi.org/motherboards/abit/BH6.htm#manu Only the 1.1+ manual mentions the d […]
Download the clocker IC datasheet now, why guess?
Even if you don't understand anything about electronics, there will be a table with accessible values
https://theretroweb.com/motherboard/image/dsc … fe919110284.jpg
https://wasp.kz/Stat_PC/m-b/ab-bh6/14_ab-bh6.jpg
w124G rev1.0 -> w196G revX.X
So, most likely, no miracle happened.
Reply 133 of 135, by myne
If you're handy with a soldering iron, there are usually same-brand clock chips that are drop-in replacements (including software).
Though that doesn't mean it will show the right text in the bios.
I built:
Reply 134 of 135, by TheMysteriousGray
Checked the BIOS and yeah, no 1/4 divider. Sucks, but I’ve got generally acceptable performance in all my games except Deus Ex, which is still a little choppy in big outdoor areas, so I’m not super torn up about it.
FromJapan was a great suggestion though, someone is selling a Voodoo 3 3500 with the big silly TV dongle for $12. As long as my bank plays nice and the card isn’t broken, I could totally experiment with Glide and just put up with the dongle. I know that even the crummy MX-4000 I have is technically more powerful, but opportunities like this don’t come around very often, right?
Reply 135 of 135, by H3nrik V!
TheMysteriousGray wrote on 2025-09-29, 15:43:
MX 4000 may be faster, but it's not GLiDE ... so if $12 and reasonably shipping costs is an option, I'd say absolutely YES!
