DFendX - the legend is reborn (again)
Reply 120 of 121, by kolderman
dosmax wrote on Today, 11:53:
DOnt't worry, I just miss my custom resolutions and cycles settings. 😀
Not at all, and custom values for some fields in a different way might be a worthy addition, I'll add that to the backlog 😀
Interesting about the staging/glide issue - which version of staging are you using? DFendX makes a distinction between older versions and newer versions, as DOSBox staging had a large rewrite around the 0.82 release. Maybe try the latest version and see if it still occurs?
Reply 121 of 121, by dosmax
Maybe you could at least add more 16:10 resolutions. A few are present, but some important ones are missing (640x400, 960x600, 1280x800, 1600x1000). There are tons of DOS games that - while most of us played them in 4:3 back in the day - actually only look correct aspect ratio wise when displayed in 16:10. Many 320x200 games have an 1:1 pixel aspect ratio and thus look vertically stretched at 4:3.
DosBox Staging 0.83 indeed solves the Glide page mystery. I'm currently stuck with 0.82.2 since 0.83 broke some "important" games for me. Should have tried that right away... The only actual glitch is the 'Glide Emulation/emu' list entry. I believe Staging currently only has on/off unless I'm mistaken. Doesn't really matter though. Consider that one closed.
