Reply 120 of 129, by digger
Scali wrote on 2018-01-17, 12:15:
Also, I previously described a way to connect up to 256 ports to a single LPT. If you put two 8-bit latches on there, you can us […]
appiah4 wrote:
Also, the serial port competes with many other peripherals that could be useful for gaming whereas the LPT is basically redundant and always available.
If you put two 8-bit latches on there, you can use one for address and one for data. A single line on the LPT selects between the two latches you write to.
You now effectively have an 8-bit address bus. With some address decoding logic, you can select between a number of chips/ports on the same device.
This should easily allow to combine an OPL3, CMS, Tandy and MPU401 on the same board.
With all these amazing projects going on, it might be time to revisit your idea. Perhaps in a separate topic/thread?
Reply 121 of 129, by matze79
The Hardware is not the Problem.
The Problem is The Software Stack for this.
Reply 122 of 129, by dreamblaster
Demo of S2P and DOS MIDI players , by Retro Erik : https://youtu.be/PF0ms6--FAM
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 123 of 129, by dreamblaster
another quick demo, of Sam and Max, using softmpu for S2P : https://youtu.be/d64iZOZBocE
Reply 124 of 129, by dreamblaster
Larry 3 demo of the new native general midi sierra SCI0 driver for S2P : https://youtu.be/SMcVZjMt11E
This driver is now included in S2PTools : https://github.com/pdewacht/s2ptools
It is based on the SCI0 Ravi General MIDI sound drivers : http://www.sierrahelp.com/Utilities/SoundUtil … undDrivers.html
Reply 125 of 129, by digger
Oooh, that SCI0 Ravi General MIDI sound driver is a cool project! Glad I learned about its existence. 😃
It will be fun to try out how these older pre-GM SCI games sound with General MIDI synths, using this driver.
Perhaps someone can also extend or fork them to support General MIDI over RS-232 (including the MPU-232 adapter) without the need for SoftMPU?
Reply 126 of 129, by dreamblaster
Demo of S2P with the RAVI GM driver for the S2P, on the HP Palmtop Tube : https://youtu.be/dnBLijJ87EE
Reply 127 of 129, by pdw
To accompany that demo, there's a new release of the S2PTools : https://github.com/pdewacht/s2ptools/releases
The Sierra driver is now based on the latest version of Ravi's original driver, and it has been fixed to work properly on 8086 and 80186 devices.
Reply 128 of 129, by dreamblaster
S2P is available again, now in green pcb version.
Reply 129 of 129, by tansoft
Has anyone managed to get Tyrian / Tyrian2K to work on Dreamblaster S2P ? I've been trying relentlessly to get it to work, but I get no midi output whatsoever... I haven't come across a patch for that game either... so wondering if anyone here had any luck with that game and the S2P ?
