Reply 120 of 127, by Anonymous Coward
- l33t++
I don't think you will need to change any PALs. First I would check if all the address lines for the cache have been wired to the chipset. If they have, then all you should have to do is add a few wires to the chipset to set the cache size. I believe it is documented in the CS82310 databook.
