Reply 120 of 124, by BinaryDemon
I do not think it's possible they are sharing the same device ID. I do not remember off hand, the earliest I'll be able to check in 12hrs. I mount C: in the command line of the script that launches DosBox because I was trying to set the volume size information at the same time, but ultimately that did not work quite right either. It's possible if you see a C: mount in startup.bat that it's some hold over from previous testing and that it's being ignored because C: is already set when DosBox is launched.
Followup: My test unit shows /mnt/sda1 as the internal flash storage.
