Reply 120 of 818, by myne
Inhibit wrote on 2024-04-24, 00:28:ascle wrote on 2024-04-23, 15:19:if it somehow did i would hope it'd have some RAM we could piggyback on but i doubt it'd have enough to matter...
i noticed the machine technically supports up to 16MB and the RAM chips are just soldered in... been debating on and off if i want to install some sockets and just slot in the max amount of RAM to see if it'd work. the only issue would be sourcing compatible chips. X)Yep, after a quick look sourcing compatible chips is a non-trivial feat. Although I'll go look through my pile of EDO DRAM on 72pin boards and see if there's something usable there. I'm guessing it'd take a daughter board, though, as I don't recall seeing that SOJ-42 package commonly when EDO DRAM was a thing.
https://au.mouser.com/ProductDetail/ISSI/IS41 … kzYf580pw%3D%3D
That's fast page which is what 386s used.
EDO is late 486/pentium era.
Don't trip on the 16Mb though. It's Mbit (2mb).
You can probably double stack them though. Iirc the top chip needs a pin shorted to differentiate it from the bottom. Don't quote me on that.
I built:
